GEN 7 V1.5 Mouser BOM
Posted by RIC79
January 29, 2013 11:42AM
hello, I'm doing a gen7 v1.5 board, however came across the problem of acquisition of the components, so I did the following link to the list of components for acquisition in the mouser site, for those who have already done it should be easy to detect if all the components are and are correct.
[www.mouser.com]
Re: GEN 7 V1.5 Mouser BOM
January 30, 2013 06:38AM
Thanks for the effort, RIC79. They ask EUR 43.36 for just the parts? Uhm. reprap-diy.com asks EUR 32.70 for the same.
February 06, 2013 01:50AM
You have MCP2200-I-SS on your list. It need to be the following if using the board Markus designed. The one you have listed is too small.
[www.mouser.com]
Brian
February 08, 2013 06:21AM
Yupp, the I/SO type is the right one.
February 21, 2013 11:00AM
Also need to change part of the terminal to the smaller size to fit the smaller connectors.
Brian
February 27, 2013 01:11PM
can you be more specific? I believe that the terminals are chosen according to the distances of the holes on the PCB board and its electrical characteristics.
Thanks for correcting previous lapse on MCP2200, BOM is already updated.
March 12, 2013 06:02AM
The terminals in your BOM only fit the larger connector for the heaters. All the other connectors need the following size terminal.
[www.mouser.com]
Edited 2 time(s). Last edit at 03/12/2013 06:14AM by sonex128.
