Gen7 v1.5: Problem with Upoading Firmware onto Atmega1284P April 22, 2013 06:09AM |
Re: Gen7 v1.5: Problem with Upoading Firmware onto Atmega1284P April 23, 2013 12:14AM |
Re: Gen7 v1.5: Problem with Upoading Firmware onto Atmega1284P April 23, 2013 06:31AM |
5) somewhere about 80-90% on the progress bar on arduino IDE, I can see the green LED (nearest to the limit switch sockets) blink once every few seconds. The one on the right remains off throughout. Then the progress bar just stays there for the longest time and at the end, I will get these messages:
"avrdude: stk500v2_ReceiveMessage(): timeout
Do I have to use a 20mhz crystal when breadboarding to use arduino isp to upload the sanguino bootloader?
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Gen7 v1.5: Problem with Upoading Firmware onto Atmega1284P April 23, 2013 07:25AM |
Re: Gen7 v1.5: Problem with Upoading Firmware onto Atmega1284P April 23, 2013 05:03PM |
Re: Gen7 v1.5: Problem with Upoading Firmware onto Atmega1284P April 23, 2013 06:50PM |
############################################################## atmega1284p-pu.name=Sanguino W/ ATmega1284p 20mhz atmega1284p-pu.upload.protocol=stk500 atmega1284p-pu.upload.maximum_size=131072 atmega1284p-pu.upload.speed=57600 atmega1284p-pu.bootloader.low_fuses=0xD6 atmega1284p-pu.bootloader.high_fuses=0xDC atmega1284p-pu.bootloader.extended_fuses=0xFD atmega1284p-pu.bootloader.path=atmega atmega1284p-pu.bootloader.file=ATmegaBOOT_168_atmega1284p.hex atmega1284p-pu.bootloader.unlock_bits=0x3F atmega1284p-pu.bootloader.lock_bits=0x0F atmega1284p-pu.build.mcu=atmega1284p atmega1284p-pu.build.f_cpu=20000000L atmega1284p-pu.build.core=arduino atmega1284p-pu.build.variant=standard
Re: Gen7 v1.5: Problem with Upoading Firmware onto Atmega1284P April 23, 2013 07:07PM |
Re: Gen7 v1.5: Problem with Upoading Firmware onto Atmega1284P April 24, 2013 03:16AM |
Re: Gen7 v1.5: Problem with Upoading Firmware onto Atmega1284P April 24, 2013 07:46AM |
What I did was to use the Sanguino bootloader
I think I'm just gonna set the Arduino as a ISP Programmer and flash the Gen7 bootloader into the 1284P via the 6 pin ISP connection
Is there a way to test if the bootloader works correctly?
I tried uploading the firmware via the programmer (the Arduino IDE offers this feature). According to the software, this was also successfull. Unfortunately, I cant connect with repetierHost and ReplicatorG. ReplicatorG gives me a timeout warning. repetierHost is very strange:If I hit power, nothing happens. If I hit the button to move Y for 1mm, the PSU powers up and everything.
Always the first time after a bootloader installation, the Rx/Tx LEDs flash like it does on an Arduino while uploading, but only the first time. After that, I get only a flash every other second.
Re: Gen7 v1.5: Problem with Upoading Firmware onto Atmega1284P May 13, 2013 08:21PM |
Re: Gen7 v1.5: Problem with Upoading Firmware onto Atmega1284P May 14, 2013 08:26AM |
