reset problems with Gen7 1.5
Posted by moltean
May 05, 2013 05:45AM
hi there,
we have built a gen7 1.5 (atmega 1284P @20 Mhz) for testing purposes.
the board seems to work ok (we have made few prints with it), but we have some problems:
1. we have to press the manual reset button each time when we try to load the marlin firmware. We connect to gen7 with a usb cable. As far as I have understood the reset is required only for usb-ttl cables. But why we need to press reset also with a usb cable ?
2. we have to press the reset button when we connect to the board with repetier. This is required only when the board is powered-up for the first time.
I have checked with the MCP2200 utility and the CTS/RTS is disabled.
any ideas are welcomed.
thank you,
mihai
Re: reset problems with Gen7 1.5
May 05, 2013 09:08AM
Apparently, auto-reset isn't working. It's a feature which hijacks the hardware handshaking lines to use it as a reset signal.
The unfortunate thing is, the signal is logical 1 with no serial line connected, too. So you see only a very short drop in voltage when connecting with a serial terminal (or Pronterface or whatever).
The red oval shows the bridge which runs the reset line. On my Gen7 the voltage drops from 5.09V to 5.06V for a second on a cheap voltage meter. Also, it's worth re-checking the solder joints in this area.
open | download - Gen7 v1.5 Reset Line.jpeg (41.7 KB)
