DISABLE_Z not working in Gen 7 1.5
May 06, 2013 06:35AM
Hi there,
I have uploaded Marlin (latest release) to our Gen 7 board.
when I set the DISABLE_Z to true, the motors (all of them) are not moving anymore.
I also have a Gen6 board, which works ok when DISABLE_Z is set to true.
is this a software or a hardware problem ?
thanks,
mihai
Re: DISABLE_Z not working in Gen 7 1.5
May 06, 2013 07:08AM
Gen7 has only one Enable line for all steppers, so if you disable one motor, you disable all of them. I guess the designer of the Gen7 finds it pretty pointless, if not asking for trouble, to disable motors while printing. winking smiley
May 06, 2013 07:19AM
Traumflug
thanks for fast reply.
here is what I want:
I want to disable the Z motor when is not used, so that I can manually move the Z axis, so that the printing head is at 0.1 mm above the bed.
I was previously working with Gen6, and there, when I start printing, I manually rotate the Z motor a little bit so that I get an optimal distance of the hotend to the print bed.
Is there some way to do this in Gen7 ?
If the Z motor is not disabled, it is very hard to move it by hand.
thanks,
mihai
May 06, 2013 08:31AM
Cut the trace to the enable pin on the Z driver, solder a link from said pin to a digital pin on the expansion header, adjust pins.h to reflect the modifications to hardware.
But the right way to do this is either:
A) Get your Z-MIN endstop in exactly the rightly place or
cool smiley Switch to a Z-MAX endstop and set its height in software so you can tell the machine where the bed is rather than set it by hand.
May 06, 2013 08:44AM
If your Z end stop is set correctly you don't need this.
Never the less, it should be a simple matter to add a switch that would turn off the enable for the Z-motor driver(s).
Bob Morrison
Wörth am Rhein, Germany
"Luke, use the source!"
BLOG - PHOTOS - Thingiverse
May 06, 2013 09:23AM
I'm constantly modifying the extruder and the hotend ... and the distance to the bead is different each time ...
this is why I prefer to manually rotate the motors in order to achive the desired distance ...
regards,
mihai
> this.
May 06, 2013 09:31AM
And why do you need to do this by hand.
Why can't you use the Pronterface Z jog buttons?
Or the keyboard/Rotary encoder button if you are running stand alone with LCD.
Bob Morrison
May 06, 2013 09:42AM
very good idea !
thanks,
mihai
May 06, 2013 10:12AM
Another solution is to add a G92 Z... after the homing command (G28) to compensate for the Z endstop misalignment.
