Re: Gen7 - Impossible to upload firmware August 20, 2013 07:36AM |
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Gen7 - Impossible to upload firmware August 21, 2013 07:23AM |
Re: Gen7 - Impossible to upload firmware August 22, 2013 04:49AM |
- Pressed reset button before uploading soft.
Took out Atmega from Gen7 and looped RX with TX pins from MCP2200. In Serial monitor I get in response exactly what i send.
One thing i noticed: when board executes test program, if i connect USB cable board stops.
Re: Gen7 - Impossible to upload firmware August 23, 2013 08:29AM |
Timeout means, there is no communications at all.
The reset is executed when you release the reset button. After a reset, the bootloader waits 3 seconds for an incoming firmware.
. And turned off power.Quote
Connecting USB usually causes an (auto-)reset. The ATmega should pick up work again a few seconds later, though.
That said, you can upload not only test firmwares, but also entire controller firmwares via ICSP.
. I would like to get it working, if i soldered it onto the board. But I almost ready to follow your advice.
Re: Gen7 - Impossible to upload firmware August 24, 2013 08:11AM |
I see what you mean: "just give up and load via ICSP"
Re: Gen7 - Impossible to upload firmware August 25, 2013 11:56PM |
Re: Gen7 - Impossible to upload firmware August 26, 2013 07:18AM |
Re: Gen7 - Impossible to upload firmware September 01, 2013 05:01PM |
Re: Gen7 - Impossible to upload firmware September 02, 2013 08:25AM |
the left green LED blinks every 8-10 sec
Re: Gen7 - Impossible to upload firmware September 02, 2013 02:26PM |
Re: Gen7 - Impossible to upload firmware September 03, 2013 06:28AM |
Re: Gen7 - Impossible to upload firmware September 18, 2013 05:18PM |
Re: Gen7 - Impossible to upload firmware September 19, 2013 06:24AM |
- tried teacup - did not work
But when i try to move the motors, they just twitch for a very very small amount and thats it.
Re: Gen7 - Impossible to upload firmware September 19, 2013 08:15AM |
Re: Gen7 - Impossible to upload firmware September 20, 2013 09:37AM |
but has the wireing schematic changed since version 1.4.1?
when i tried to upload the teacup firmware, it did not even turn the "psu" LED on near the lower right side(next to the USB port).
Re: Gen7 - Impossible to upload firmware September 21, 2013 02:04PM |
Re: Gen7 - Impossible to upload firmware September 22, 2013 11:12AM |
The firmware uploads fine, but when using pronterface or repetier host, neither can turn the psu on.
Re: Gen7 - Impossible to upload firmware September 27, 2013 07:13PM |
Re: Gen7 - Impossible to upload firmware September 30, 2013 09:59AM |
Re: Gen7 - Impossible to upload firmware September 30, 2013 11:44AM |
I am having problem with MCP2200.
If I load firmware (Teacup) via ISP into 1284P and connect it to Pronteface I have message 'start' repeated infinite.
FT232 does not work if i don't solder out MCP2200.
Auto reset?
Re: Gen7 - Impossible to upload firmware October 01, 2013 07:15AM |
Re: Gen7 - Impossible to upload firmware November 14, 2013 07:40AM |
Re: Gen7 - Impossible to upload firmware January 17, 2014 11:07AM |
Re: Gen7 - Impossible to upload firmware January 19, 2014 01:46AM |
Re: Gen7 - Impossible to upload firmware January 19, 2014 08:51AM |
Re: Gen7 - Impossible to upload firmware January 20, 2014 11:38AM |
Re: Gen7 - Impossible to upload firmware January 21, 2014 01:14AM |
Admin Registered: 15 years ago Posts: 7,337 |
Re: Gen7 - Impossible to upload firmware January 25, 2014 03:15PM |
Re: Gen7 - Impossible to upload firmware August 15, 2015 07:11PM |
Re: Gen7 - Impossible to upload firmware August 16, 2015 04:26PM |
aaron.r
Hello,
I'm unable to verify the Setup program - I get the below errors, captured with "verbose output" during compilation. In case it helps, I added a note where the error list begins.
I have a Gen7 v1.5, Ubuntu Linux.
/usr/share/arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega1284p -DF_CPU=20000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/home/aaron/sketchbook/hardware/Gen7/cores/arduino
-I/home/aaron/sketchbook/hardware/Gen7/variants/gen7 /tmp/build6012115862471332917.tmp/sketch_aug11a.cpp -o /tmp/build6012115862471332917.tmp/sketch_aug11a.cpp.o
Errors:
/home/aaron/sketchbook/hardware/Gen7/cores/arduino/WString.cpp: In member function ‘void String::init()’:
/home/aaron/sketchbook/hardware/Gen7/cores/arduino/WString.cpp:117:2: error: ‘flags’ was not declared in this scope
flags = 0;
