Thanks for the advice - I made sure that the package came from the Gen 7 support file and it is now compiling. It is not uploading, however. When I open the serial window, the pre-loaded Setup Test program kicks on and shows on/off text as the bed LED blinks on and off. When I try to upload the Setup Test program again, it begins to upload, but doesn't seem to finish. I have the Upload messages below as well:
Compiling messages:
/usr/share/arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega1284p -DF_CPU=20000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/home/rhodes/sketchbook/hardware/Gen7/cores/arduino -I/home/rhodes/sketchbook/hardware/Gen7/variants/gen7 /tmp/build8685151425230593942.tmp/setup_test_Gen7_v1_5.cpp -o /tmp/build8685151425230593942.tmp/setup_test_Gen7_v1_5.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega1284p -DF_CPU=20000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/home/rhodes/sketchbook/hardware/Gen7/cores/arduino -I/home/rhodes/sketchbook/hardware/Gen7/variants/gen7 /home/rhodes/sketchbook/hardware/Gen7/cores/arduino/wiring_analog.c -o /tmp/build8685151425230593942.tmp/wiring_analog.c.o
/usr/share/arduino/hardware/tools/avr/bin/avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega1284p -DF_CPU=20000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/home/rhodes/sketchbook/hardware/Gen7/cores/arduino -I/home/rhodes/sketchbook/hardware/Gen7/variants/gen7 /home/rhodes/sketchbook/hardware/Gen7/cores/arduino/wiring.c -o /tmp/build8685151425230593942.tmp/wiring.c.o
/usr/share/arduino/hardware/tools/avr/bin/avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega1284p -DF_CPU=20000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/home/rhodes/sketchbook/hardware/Gen7/cores/arduino -I/home/rhodes/sketchbook/hardware/Gen7/variants/gen7 /home/rhodes/sketchbook/hardware/Gen7/cores/arduino/wiring_digital.c -o /tmp/build8685151425230593942.tmp/wiring_digital.c.o
In file included from /home/rhodes/sketchbook/hardware/Gen7/cores/arduino/Arduino.h:220:0,
from /home/rhodes/sketchbook/hardware/Gen7/cores/arduino/wiring_private.h:33,
from /home/rhodes/sketchbook/hardware/Gen7/cores/arduino/wiring_digital.c:28:
/home/rhodes/sketchbook/hardware/Gen7/variants/gen7/pins_arduino.h:103:2: warning: initialization makes integer from pointer without a cast [enabled by default]
&DDRA,
/home/rhodes/sketchbook/hardware/Gen7/variants/gen7/pins_arduino.h:103:2: warning: (near initialization for ‘port_to_mode_PGM[1]’) [enabled by default]
/home/rhodes/sketchbook/hardware/Gen7/variants/gen7/pins_arduino.h:104:2: warning: initialization makes integer from pointer without a cast [enabled by default]
&DDRB,
/home/rhodes/sketchbook/hardware/Gen7/variants/gen7/pins_arduino.h:104:2: warning: (near initialization for ‘port_to_mode_PGM[2]’) [enabled by default]
/home/rhodes/sketchbook/hardware/Gen7/variants/gen7/pins_arduino.h:105:2: warning: initialization makes integer from pointer without a cast [enabled by default]
&DDRC,
/home/rhodes/sketchbook/hardware/Gen7/variants/gen7/pins_arduino.h:105:2: warning: (near initialization for ‘port_to_mode_PGM[3]’) [enabled by default]
/home/rhodes/sketchbook/hardware/Gen7/variants/gen7/pins_arduino.h:106:2: warning: initialization makes integer from pointer without a cast [enabled by default]
&DDRD,
/home/rhodes/sketchbook/hardware/Gen7/variants/gen7/pins_arduino.h:106:2: warning: (near initialization for ‘port_to_mode_PGM[4]’) [enabled by default]
/home/rhodes/sketchbook/hardware/Gen7/variants/gen7/pins_arduino.h:111:2: warning: initialization makes integer from pointer without a cast [enabled by default]
&PORTA,
/home/rhodes/sketchbook/hardware/Gen7/variants/gen7/pins_arduino.h:111:2: warning: (near initialization for ‘port_to_output_PGM[1]’) [enabled by default]
/home/rhodes/sketchbook/hardware/Gen7/variants/gen7/pins_arduino.h:112:2: warning: initialization makes integer from pointer without a cast [enabled by default]
&PORTB,
/home/rhodes/sketchbook/hardware/Gen7/variants/gen7/pins_arduino.h:112:2: warning: (near initialization for ‘port_to_output_PGM[2]’) [enabled by default]
/home/rhodes/sketchbook/hardware/Gen7/variants/gen7/pins_arduino.h:113:2: warning: initialization makes integer from pointer without a cast [enabled by default]
&PORTC,
/home/rhodes/sketchbook/hardware/Gen7/variants/gen7/pins_arduino.h:113:2: warning: (near initialization for ‘port_to_output_PGM[3]’) [enabled by default]
/home/rhodes/sketchbook/hardware/Gen7/variants/gen7/pins_arduino.h:114:2: warning: initialization makes integer from pointer without a cast [enabled by default]
&PORTD,
/home/rhodes/sketchbook/hardware/Gen7/variants/gen7/pins_arduino.h:114:2: warning: (near initialization for ‘port_to_output_PGM[4]’) [enabled by default]
/home/rhodes/sketchbook/hardware/Gen7/variants/gen7/pins_arduino.h:119:2: warning: initialization makes integer from pointer without a cast [enabled by default]
&PINA,
/home/rhodes/sketchbook/hardware/Gen7/variants/gen7/pins_arduino.h:119:2: warning: (near initialization for ‘port_to_input_PGM[1]’) [enabled by default]
/home/rhodes/sketchbook/hardware/Gen7/variants/gen7/pins_arduino.h:120:2: warning: initialization makes integer from pointer without a cast [enabled by default]
&PINB,
/home/rhodes/sketchbook/hardware/Gen7/variants/gen7/pins_arduino.h:120:2: warning: (near initialization for ‘port_to_input_PGM[2]’) [enabled by default]
/home/rhodes/sketchbook/hardware/Gen7/variants/gen7/pins_arduino.h:121:2: warning: initialization makes integer from pointer without a cast [enabled by default]
&PINC,
/home/rhodes/sketchbook/hardware/Gen7/variants/gen7/pins_arduino.h:121:2: warning: (near initialization for ‘port_to_input_PGM[3]’) [enabled by default]
/home/rhodes/sketchbook/hardware/Gen7/variants/gen7/pins_arduino.h:122:2: warning: initialization makes integer from pointer without a cast [enabled by default]
&PIND,
/home/rhodes/sketchbook/hardware/Gen7/variants/gen7/pins_arduino.h:122:2: warning: (near initialization for ‘port_to_input_PGM[4]’) [enabled by default]
/usr/share/arduino/hardware/tools/avr/bin/avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega1284p -DF_CPU=20000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/home/rhodes/sketchbook/hardware/Gen7/cores/arduino -I/home/rhodes/sketchbook/hardware/Gen7/variants/gen7 /home/rhodes/sketchbook/hardware/Gen7/cores/arduino/wiring_shift.c -o /tmp/build8685151425230593942.tmp/wiring_shift.c.o
/usr/share/arduino/hardware/tools/avr/bin/avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega1284p -DF_CPU=20000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/home/rhodes/sketchbook/hardware/Gen7/cores/arduino -I/home/rhodes/sketchbook/hardware/Gen7/variants/gen7 /home/rhodes/sketchbook/hardware/Gen7/cores/arduino/WInterrupts.c -o /tmp/build8685151425230593942.tmp/WInterrupts.c.o
/home/rhodes/sketchbook/hardware/Gen7/cores/arduino/WInterrupts.c: In function ‘__vector_3’:
/home/rhodes/sketchbook/hardware/Gen7/cores/arduino/WInterrupts.c:309:13: warning: array subscript is above array bounds [-Warray-bounds]
if(intFunc[EXTERNAL_INT_2])
/home/rhodes/sketchbook/hardware/Gen7/cores/arduino/WInterrupts.c:310:12: warning: array subscript is above array bounds [-Warray-bounds]
intFunc[EXTERNAL_INT_2]();
/usr/share/arduino/hardware/tools/avr/bin/avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega1284p -DF_CPU=20000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/home/rhodes/sketchbook/hardware/Gen7/cores/arduino -I/home/rhodes/sketchbook/hardware/Gen7/variants/gen7 /home/rhodes/sketchbook/hardware/Gen7/cores/arduino/wiring_pulse.c -o /tmp/build8685151425230593942.tmp/wiring_pulse.c.o
/usr/share/arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega1284p -DF_CPU=20000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/home/rhodes/sketchbook/hardware/Gen7/cores/arduino -I/home/rhodes/sketchbook/hardware/Gen7/variants/gen7 /home/rhodes/sketchbook/hardware/Gen7/cores/arduino/IPAddress.cpp -o /tmp/build8685151425230593942.tmp/IPAddress.cpp.o
In file included from /home/rhodes/sketchbook/hardware/Gen7/cores/arduino/IPAddress.cpp:3:0:
/home/rhodes/sketchbook/hardware/Gen7/cores/arduino/IPAddress.h: In member function ‘IPAddress
perator uint32_t()’:
/home/rhodes/sketchbook/hardware/Gen7/cores/arduino/IPAddress.h:51:55: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
operator uint32_t() { return *((uint32_t*)_address); };
/home/rhodes/sketchbook/hardware/Gen7/cores/arduino/IPAddress.h: In member function ‘bool IPAddress
perator==(const IPAddress&)’:
/home/rhodes/sketchbook/hardware/Gen7/cores/arduino/IPAddress.h:52:75: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
bool operator==(const IPAddress& addr) { return (*((uint32_t*)_address)) == (*((uint32_t*)addr._address)); };
/home/rhodes/sketchbook/hardware/Gen7/cores/arduino/IPAddress.h:52:108: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
/usr/share/arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega1284p -DF_CPU=20000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/home/rhodes/sketchbook/hardware/Gen7/cores/arduino -I/home/rhodes/sketchbook/hardware/Gen7/variants/gen7 /home/rhodes/sketchbook/hardware/Gen7/cores/arduino/CDC.cpp -o /tmp/build8685151425230593942.tmp/CDC.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega1284p -DF_CPU=20000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/home/rhodes/sketchbook/hardware/Gen7/cores/arduino -I/home/rhodes/sketchbook/hardware/Gen7/variants/gen7 /home/rhodes/sketchbook/hardware/Gen7/cores/arduino/HardwareSerial.cpp -o /tmp/build8685151425230593942.tmp/HardwareSerial.cpp.o
/home/rhodes/sketchbook/hardware/Gen7/cores/arduino/HardwareSerial.cpp: In function ‘void store_char(unsigned char, ring_buffer*)’:
/home/rhodes/sketchbook/hardware/Gen7/cores/arduino/HardwareSerial.cpp:98:20: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
if (i != buffer->tail) {
/home/rhodes/sketchbook/hardware/Gen7/cores/arduino/HardwareSerial.cpp: In function ‘void __vector_20()’:
/home/rhodes/sketchbook/hardware/Gen7/cores/arduino/HardwareSerial.cpp:132:21: warning: unused variable ‘c’ [-Wunused-variable]
unsigned char c = UDR0;
/home/rhodes/sketchbook/hardware/Gen7/cores/arduino/HardwareSerial.cpp: In function ‘void __vector_28()’:
/home/rhodes/sketchbook/hardware/Gen7/cores/arduino/HardwareSerial.cpp:158:21: warning: unused variable ‘c’ [-Wunused-variable]
unsigned char c = UDR1;
/home/rhodes/sketchbook/hardware/Gen7/cores/arduino/HardwareSerial.cpp: In member function ‘void HardwareSerial::begin(long unsigned int, byte)’:
/home/rhodes/sketchbook/hardware/Gen7/cores/arduino/HardwareSerial.cpp:379:11: warning: unused variable ‘current_config’ [-Wunused-variable]
uint8_t current_config;
/home/rhodes/sketchbook/hardware/Gen7/cores/arduino/HardwareSerial.cpp: In member function ‘virtual size_t HardwareSerial::write(uint8_t)’:
/home/rhodes/sketchbook/hardware/Gen7/cores/arduino/HardwareSerial.cpp:478:27: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
while (i == _tx_buffer->tail)
/usr/share/arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega1284p -DF_CPU=20000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/home/rhodes/sketchbook/hardware/Gen7/cores/arduino -I/home/rhodes/sketchbook/hardware/Gen7/variants/gen7 /home/rhodes/sketchbook/hardware/Gen7/cores/arduino/new.cpp -o /tmp/build8685151425230593942.tmp/new.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega1284p -DF_CPU=20000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/home/rhodes/sketchbook/hardware/Gen7/cores/arduino -I/home/rhodes/sketchbook/hardware/Gen7/variants/gen7 /home/rhodes/sketchbook/hardware/Gen7/cores/arduino/WMath.cpp -o /tmp/build8685151425230593942.tmp/WMath.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega1284p -DF_CPU=20000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/home/rhodes/sketchbook/hardware/Gen7/cores/arduino -I/home/rhodes/sketchbook/hardware/Gen7/variants/gen7 /home/rhodes/sketchbook/hardware/Gen7/cores/arduino/Stream.cpp -o /tmp/build8685151425230593942.tmp/Stream.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega1284p -DF_CPU=20000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/home/rhodes/sketchbook/hardware/Gen7/cores/arduino -I/home/rhodes/sketchbook/hardware/Gen7/variants/gen7 /home/rhodes/sketchbook/hardware/Gen7/cores/arduino/Print.cpp -o /tmp/build8685151425230593942.tmp/Print.cpp.o
/home/rhodes/sketchbook/hardware/Gen7/cores/arduino/Print.cpp: In member function ‘size_t Print::print(const __FlashStringHelper*)’:
/home/rhodes/sketchbook/hardware/Gen7/cores/arduino/Print.cpp:44:23: warning: ‘__progmem__’ attribute ignored [-Wattributes]
const char PROGMEM *p = (const char PROGMEM *)ifsh;
/usr/share/arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega1284p -DF_CPU=20000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/home/rhodes/sketchbook/hardware/Gen7/cores/arduino -I/home/rhodes/sketchbook/hardware/Gen7/variants/gen7 /home/rhodes/sketchbook/hardware/Gen7/cores/arduino/main.cpp -o /tmp/build8685151425230593942.tmp/main.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega1284p -DF_CPU=20000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/home/rhodes/sketchbook/hardware/Gen7/cores/arduino -I/home/rhodes/sketchbook/hardware/Gen7/variants/gen7 /home/rhodes/sketchbook/hardware/Gen7/cores/arduino/HID.cpp -o /tmp/build8685151425230593942.tmp/HID.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega1284p -DF_CPU=20000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/home/rhodes/sketchbook/hardware/Gen7/cores/arduino -I/home/rhodes/sketchbook/hardware/Gen7/variants/gen7 /home/rhodes/sketchbook/hardware/Gen7/cores/arduino/Tone.cpp -o /tmp/build8685151425230593942.tmp/Tone.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega1284p -DF_CPU=20000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/home/rhodes/sketchbook/hardware/Gen7/cores/arduino -I/home/rhodes/sketchbook/hardware/Gen7/variants/gen7 /home/rhodes/sketchbook/hardware/Gen7/cores/arduino/USBCore.cpp -o /tmp/build8685151425230593942.tmp/USBCore.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega1284p -DF_CPU=20000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/home/rhodes/sketchbook/hardware/Gen7/cores/arduino -I/home/rhodes/sketchbook/hardware/Gen7/variants/gen7 /home/rhodes/sketchbook/hardware/Gen7/cores/arduino/WString.cpp -o /tmp/build8685151425230593942.tmp/WString.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-ar rcs /tmp/build8685151425230593942.tmp/core.a /tmp/build8685151425230593942.tmp/wiring_analog.c.o
/usr/share/arduino/hardware/tools/avr/bin/avr-ar rcs /tmp/build8685151425230593942.tmp/core.a /tmp/build8685151425230593942.tmp/wiring.c.o
/usr/share/arduino/hardware/tools/avr/bin/avr-ar rcs /tmp/build8685151425230593942.tmp/core.a /tmp/build8685151425230593942.tmp/wiring_digital.c.o
/usr/share/arduino/hardware/tools/avr/bin/avr-ar rcs /tmp/build8685151425230593942.tmp/core.a /tmp/build8685151425230593942.tmp/wiring_shift.c.o
/usr/share/arduino/hardware/tools/avr/bin/avr-ar rcs /tmp/build8685151425230593942.tmp/core.a /tmp/build8685151425230593942.tmp/WInterrupts.c.o
/usr/share/arduino/hardware/tools/avr/bin/avr-ar rcs /tmp/build8685151425230593942.tmp/core.a /tmp/build8685151425230593942.tmp/wiring_pulse.c.o
/usr/share/arduino/hardware/tools/avr/bin/avr-ar rcs /tmp/build8685151425230593942.tmp/core.a /tmp/build8685151425230593942.tmp/IPAddress.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-ar rcs /tmp/build8685151425230593942.tmp/core.a /tmp/build8685151425230593942.tmp/CDC.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-ar rcs /tmp/build8685151425230593942.tmp/core.a /tmp/build8685151425230593942.tmp/HardwareSerial.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-ar rcs /tmp/build8685151425230593942.tmp/core.a /tmp/build8685151425230593942.tmp/new.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-ar rcs /tmp/build8685151425230593942.tmp/core.a /tmp/build8685151425230593942.tmp/WMath.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-ar rcs /tmp/build8685151425230593942.tmp/core.a /tmp/build8685151425230593942.tmp/Stream.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-ar rcs /tmp/build8685151425230593942.tmp/core.a /tmp/build8685151425230593942.tmp/Print.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-ar rcs /tmp/build8685151425230593942.tmp/core.a /tmp/build8685151425230593942.tmp/main.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-ar rcs /tmp/build8685151425230593942.tmp/core.a /tmp/build8685151425230593942.tmp/HID.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-ar rcs /tmp/build8685151425230593942.tmp/core.a /tmp/build8685151425230593942.tmp/Tone.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-ar rcs /tmp/build8685151425230593942.tmp/core.a /tmp/build8685151425230593942.tmp/USBCore.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-ar rcs /tmp/build8685151425230593942.tmp/core.a /tmp/build8685151425230593942.tmp/WString.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-gcc -Os -Wl,--gc-sections -mmcu=atmega1284p -o /tmp/build8685151425230593942.tmp/setup_test_Gen7_v1_5.cpp.elf /tmp/build8685151425230593942.tmp/setup_test_Gen7_v1_5.cpp.o /tmp/build8685151425230593942.tmp/core.a -L/tmp/build8685151425230593942.tmp -lm
/usr/share/arduino/hardware/tools/avr/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /tmp/build8685151425230593942.tmp/setup_test_Gen7_v1_5.cpp.elf /tmp/build8685151425230593942.tmp/setup_test_Gen7_v1_5.cpp.eep
/usr/share/arduino/hardware/tools/avr/bin/avr-objcopy -O ihex -R .eeprom /tmp/build8685151425230593942.tmp/setup_test_Gen7_v1_5.cpp.elf /tmp/build8685151425230593942.tmp/setup_test_Gen7_v1_5.cpp.hex
Binary sketch size: 3,256 bytes (of a 129,024 byte maximum)
Upload messages: (I've removed some of the repetitive "avrdude: Recv: . [00] " text)
avrdude: Version 6.0.1, compiled on Oct 21 2013 at 17:07:18
Copyright (c) 2000-2005 Brian Dean, [
www.bdmicro.com]
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/usr/share/arduino/hardware/tools/avrdude.conf"
User configuration file is "/home/rhodes/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyACM4
Using Programmer : stk500v2
Overriding Baud Rate : 115200
avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14]
avrdude: ser_recv(): programmer is not responding
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
AVR Part : ATmega1284P
Chip Erase delay : 55000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 128 0 no 4096 8 0 9000 9000 0xff 0xff
flash 65 10 256 0 yes 131072 256 512 4500 4500 0xff 0xff
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
Programmer Type : STK500V2
Description : Atmel STK500 Version 2.x firmware
Programmer Model: Unknown
avrdude: Send: . [1b] . [01] . [00] . [02] . [0e] . [03] . [90] . [85]
