Hello,
I'm currently finishing my third delta printer and hit a very strange error - i cannot get my backup laptop to communicate with MCP2200.
My main laptop has Win 7 OS, 64 bit. There I got the whole board working with some troubles but nothing too bad.
Because i'm on my backup, I assumed it would work easier, since its 32 bit XP, but unfortunately it did not.
I've tried the following things:
- installed MCP2200 drivers from the manufacturers homepage
- installed MCP2200 configuration app from the manufacturers homepage
- uninstalled and unplugged all other USB devices and reset the com ports in the device manager
- swapped to a completely unused board to see if something was wrong(there was nothing wrong).
I read through about 6-7 threads in this subforum relating to MCP 2200 issues but was not able to find a solution. I would like to point out that the board was a kit from Traumflugs shop, so everything should be good and dandy(since the other two boards work great).
Thanks for any and all help
P.S. - i tried swapping out the working board from my other delta to the one i'm building right now and same issue - MCP2200 does not communicate in 32bit XP, while when I connceted the blank board to the WIN 7 64 bit laptop, I managed to upload setuptest and then the firmware itself.
