Gen7 Brushless ESC
Posted by formulavee
Gen7 Brushless ESC
February 22, 2014 04:36AM
Hey,
I am new here and was wondering if any one could help me with some thing....
For my Year 11 project I am making a CNC router, I was wondering if (an how) you could connect a brushless ESC (to run a brushless outrunner, 10amp max) to a Gen7 1.5 board to use as the spindle controller
Any help would be much appriciated spinning smiley sticking its tongue out
Edited 1 time(s). Last edit at 02/22/2014 04:39AM by formulavee.
Re: Gen7 Brushless ESC
February 26, 2014 07:27PM
I saw this on ebay
apparently you can connect a ESC up to this and it sends them the same signal that you would get from a receiver...
February 27, 2014 07:26AM
My very quick look at the thing did not reveal any control input specification but, assume you have a digital "on" input pin and an analog "speed" input pin. Then you could use the dir or forward/reverse signal for the extruder motor as "on" for your spindle and use the PWM signal for the extruder heater for "speed" control.
February 28, 2014 12:26AM
Hobby ESC's expect a servo-type control signal. In fact, you can use the Arduino servo library to control a brushless ESC and motor. I know that Marlin natively supports servo control, and other firmwares probably do as well. This way you could just have a gcode command to turn the spindle on and off and control the speed.
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing.
Anyone can edit the wiki!
