Re: Generation 7 Electronics Development December 27, 2012 12:49AM |
Re: Generation 7 Electronics Development December 27, 2012 12:04PM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Generation 7 Electronics Development December 28, 2012 10:36AM |
Re: Generation 7 Electronics Development December 28, 2012 04:12PM |
Re: Generation 7 Electronics Development January 01, 2013 06:39AM |
I see the mcp2200 does not have DTR? Can i still upload firmware with it?
Re: Generation 7 Electronics Development January 01, 2013 06:46AM |
Re: Generation 7 Electronics Development January 02, 2013 09:17AM |
Re: Generation 7 Electronics Development January 02, 2013 08:30PM |
Re: Generation 7 Electronics Development January 03, 2013 01:26AM |
Re: Generation 7 Electronics Development January 03, 2013 05:23AM |
Re: Generation 7 Electronics Development January 03, 2013 03:55PM |
Re: Generation 7 Electronics Development January 03, 2013 07:55PM |
Re: Generation 7 Electronics Development January 04, 2013 02:33AM |
Re: Generation 7 Electronics Development January 04, 2013 06:37AM |
bobc
I can't see how the self-powered mode is supposed to work, there seems to be some functionality missing.
peter 6960
Soldered up the second one - enumerated immediately.
Re: Generation 7 Electronics Development January 04, 2013 11:05AM |
Back-power: “Self-powered” USB devices can also have their own power problems. Since self-powered devices have their own independent power supplies, they can be ON while the host is turned OFF. This causes a potential problem where the small pull-up voltage applied to D+ to enable USB device detection slowly charges up the entire host system and interferes with startup. Self-powered USB devices (including battery-powered devices) must either drive this pull-up directly from VBUS or turn it off via software control using a VBUS sensor.
Re: Generation 7 Electronics Development January 05, 2013 08:11AM |
Re: Generation 7 Electronics Development January 05, 2013 08:30AM |
Re: Generation 7 Electronics Development January 06, 2013 08:30AM |
Re: Generation 7 Electronics Development January 06, 2013 08:33AM |
Re: Generation 7 Electronics Development January 11, 2013 01:47PM |
Re: Generation 7 Electronics Development January 11, 2013 09:24PM |
Admin Registered: 17 years ago Posts: 7,879 |
Annirak
For the cost of two resistors, an LED and a transistor, you can have 100% resolution across the measurable range. All you need is a current source to feed the thermistor.
Traumflug
But how would we convice the hotend makers to put a diode into their work instead of a n thermistor?
Re: Generation 7 Electronics Development January 15, 2013 04:10AM |
Re: Generation 7 Electronics Development January 15, 2013 04:23AM |
Admin Registered: 16 years ago Posts: 13,874 |
Re: Generation 7 Electronics Development January 15, 2013 07:45AM |
... the biggest problem with current temperature measuring/controlling is the poor resolution of the analog inputs.
Re: Generation 7 Electronics Development January 15, 2013 08:01AM |
Re: Generation 7 Electronics Development January 15, 2013 03:10PM |
Re: Generation 7 Electronics Development January 16, 2013 04:06AM |
Re: Generation 7 Electronics Development January 16, 2013 04:20AM |
Re: Generation 7 Electronics Development January 16, 2013 06:11AM |
The best resolution is where the thermistor equals the resistor value.
In my graphs the slope looks like it only changes about 2 or 3 : 1 and is symmetrical. Why is your example of 100K and 4K7 skewed to the bottom end? Which thermistor is it based on?
Re: Generation 7 Electronics Development January 16, 2013 07:18AM |
