Generation 7 Electronics Development
Posted by Traumflug
Re: Generation 7 Electronics Development
March 08, 2013 12:37PM
peter6960
Yes...
I ticked Enable RX/tax LEDs Untucked enable CTS/RTS - with it ticked auto reset did not work.
Circuit spot on. Works out of the box...
I've been trying to using the 1.5 board with Pronterface, but the only way to do the connection is by enabling CTS/RTS. With this option unchecked I'm be able to connect using gtkterm (or another similar serial terminal), but not Pronterface (Cura sometimes connect, sometimes don't).
I also noticed that MCP2200 baudrate is changed wihen CTS/RTS option is enabled: it's at 19200 before trying to connect using Pronterface, and it's 115200 after that.
I don't know the reason, maybe some Pronterface issues with the python serial module.
Is there any serious hardware problem if this option is enabled?
PS. With this option checked manually reset is needed to do any firmware upload.
March 21, 2013 07:45AM
Does anybody have a good idea on how to make the indicator LEDs of the MOSFETs compatible with 24V?
The current situation is, there's nothing stopping one from operating a Gen7 with 24V for the motors and/or the heaters, except these indicator LEDs. For 12V, they need a pre-resistor 500 to 1000 ohms, for 24V at least 1500 ohms.
Solutions I've though of:
- Make the pre-resistor big and live with less light when operated on 12V.
- Move the indicator LED the the ATmega pin / MOSFET gate side. There's always 5V independently from the heater voltage. Sucks away precious current to fill the MOSFET gate, of course.
- Get rid of the indicator LED altogether. Saves even a few parts.
What do you think?
VDX
March 21, 2013 08:09AM
... insert an optocoupler, that 'triggers' from 4V to 24V winking smiley
Viktor
March 21, 2013 11:13AM
Traumflug
I've no idea, but RAMPS, Megatronics, Azteeg and some other electronics have 1800 ohms resistors for MOSFETs LEDs and usually are operated by 12V in most of the scenarios.
March 21, 2013 03:41PM
How about just specifying it as option: You solder in based on what you intend running on? No need to change board for that. I use 12v almost exclusively and love the bright LEDs showing heater are on
March 22, 2013 03:52AM
Or use a constant-current diode instead of a resistor.
e.g. On Semi NSI50010YT1G
Some more info: Constant current diodes are a two-pin device, which is a diode in one direction and a current regulator in the other. They're made by connecting a n-channel jfet with its drain to one terminal, its gate to the other, and a resistor between the gate and the source.
They're known under a number of names:
CCR: Constant Current Regulator (On Semi)
CLD: Current Limiting Diode (Central Semi)
CCD: Constant Current Diode (Vishay)
Though, it seems that Vishay has discontinued their whole line.
OnSemi's line is available through digikey and seems to run from about 2.2mA to 90mA. Obviously, the packages and voltage ratings change a few times in there to account for the power dissipation.
If you're looking for them on Digikey, you end up with some weird results. So, to help you out, they're in:
Product Index > Integrated Circuits (ICs) > PMIC - Current Regulation/Management
Then restrict matches to "Current Regulator"
Edited 1 time(s). Last edit at 03/22/2013 04:05AM by Annirak.
March 23, 2013 08:20AM
Another one answered by PM ("too lazy to translate to english" smiling smiley ) He suggested using two resistors in series. Additionally a jumper to short one of the resistors when operating at 12V. Sounds reasonable.
March 31, 2013 12:19PM
I actually etched up on of Xoan's GEN7S's today
With white painted topside and toner transfered silkscreen it actually looks quite sexy
And compared to a regular Gen 7 - the form factor change did not sound like much on paper, but in reality it really is a lot smaller
And lastly - as most of you know I have a redrawn copy of the Gen 7 in eagle I use for my own botfarm - staying as close to possible to the original in terms of standards and pinouts.
Well, I managed to get the SD card onto the PCB itself (less expansion) and also routed in a 4 pin header for 5v/gnd/sda/scl and another 4 pin for the encoder
Here's a view of the SD (Yamachi FPS300* series SD card holders), placed approx where the endstops on regular Gebn 7 would be.
Think its a nice integration for the main branch... More printrboardish
xoan Wrote:
> > - ATX24 and 4 ways on different sides of board.
> So no matter how you try the thicker PSU cables
> has to ho over or under the PCB or other wires. If
> someone finds away to put all power circuitry to
> one side, wiring would be a dream
> Sure, but I believe a lot of rework would be
> required in order to achieve that. In the smaller
> PCB I've been doing I think that may be
> impossible.
> - mcp2200 reset. The reenumaration dance gets less
> exciting as time goes on
> - reset switch. Behind USB socket = very difficult
> to reach in emergency or otherwise. Move it closer
> to board edge
> I've no trouble with MCP2200 reenumeration so
> reset switch can be moved closer to the board edge
> but leaving unaccessible the USB5V output (see
> attached layout).
Edited 1 time(s). Last edit at 03/31/2013 12:19PM by peter6960.
April 13, 2013 12:39AM
Hi I have finished my GEN7 1.5 board and it passes all the pre test with test software. I have Ardunio 1.0.3, and installed the Gen7+Arduino+IDE+Support+2.1.zip into the hardware folder under the Ardunio folder. Got the Repetier-Firmware ver .82 and found the reference about the TEMP_2_PIN and HEATER_2_PIN. It compiles fine. Uploads fine, but when I try this command M500 in the Pronterface it gives me this message:
Connecting...
start
Printer is now online.
External Reset
>>>M500
SENDING:M500
Error: Missing checksum
continually prints resend.
note - I turned of the wait message for know
Don't now your code and now clue as to where to start looking in it. I now the serial hardware is working as it worked with the test application. even at the 115200 baud rate. So I am thinking its firmware or build Environmen. Any Suggestions? Test programs?
April 13, 2013 05:57AM
Great you got your electronics working flawlessly.
The error you see is indeed a firmware problem. Apparently, Repetier insists on a checksum, but the host doesn't send one. Repetier is active in his own forum section: [forums.reprap.org]
April 16, 2013 05:02PM
If you still have not managed:
here's my working environment with Repetier - preconfigured for Gen 7 1.5/1.4.1 with SD
[kzn.house4hack.co.za]
April 18, 2013 11:37AM
Thanks I will give it a Try
Help, Gen7 v1.5
where to read?
avrdude: stk500_getsync(): not in sync: resp=0x00
May 01, 2013 06:56AM
where to read?
What did you do, which bootloader do you use, are you running 16 MHz or 20 MHz, ... ? Answers can only be informative if you describe what you tried.
Gen7 v1.5 20 MHz (ATmega 644-20P), [reprap.org]. I need to load the bootloader, used arduino-1.0.3 and Gen7 + Arduino + IDE + Support +2.1
I am a newbie, you can describe the steps? We need to load the first programmer in Gen7 1.5?
Please step by step ... 1, 2, 3 ...., .....
Sorry for bad English.
May 01, 2013 06:22PM
Step by step [1], both command line (for Linux and Windows) and IDE flavour smiling smiley
[1] [reprap.org]
thank you
May 03, 2013 10:37AM
This is in regards to post 103, looks Good, but you relay do need a good Heat sink on Heater switches. They run a Lot cooler then the melzi board, but tack longer to Heat. and if you run the printer on large prints like 6 hour or more the heat starts to clime, and I have seen up to and above 48C with as big a Heat sink as I can put on them. We cant get mica Insulators hear any more so I needed two separate Heat sinks.
Just some Suggestion, as and Old Electronics man I would Suggest putting only the X, Y, Z, Heated bead, USB and Programing port circuitry on the Main board. Us the Expansion boards for say, Extruders and Hot ends, Blue tooth, NIC, Displays (Tools). Reasoning as its modular. A growing number of people wont to be able to choose 1 - 3 Hot ends. Another concern is 3 Extruders (Drives and Hot ends) can be put on another Processor using I2c or other Serial protocols to transfer the commands to the appropriate module. This levis us with a FW for the main board that Just handles One heat controller, all the Drive stuff and command parsing. Personally, I would like to get and expansion board with Second processor on it and be able to populate it with the electronics for 1, 2 or 3 Extruder drives and heaters.
Another way to look at this is all tools are on expansion boards, and are just routed the tool commands from the main board.
Tools = Extruders & Hot end, Cooling fanes, Secondary command Devices (Blue tooth, NIC, SD Card, Front panels).
Any ways, just the thoughts of and old man (Suggestions, that may be in appropriate).
May 04, 2013 10:13AM
48 °C is barely above room temperature, isn't it? winking smiley
In my test series, MOSFETs survived 120 °C measured at the heatsink easily: [reprap.org]
May 04, 2013 10:23AM
P.S.: I agree with the other parts and putting non-basic stuff on the extension board is what I have in mind.
May 06, 2013 12:39PM
that was 48C with a big heat sink on them. Without the Heat Sink they hotbed one burns your fingers. But more importantly the Connecter for the 12V supply and the board, despite the fact I put ample amounts of solder, is burning. It is also burning the insulation from the power supply on the 12V lead. I could probably up the Voltage to 24V, but I am thinking I am at my max wattage through that connecter. Mite try using a connector for the PCIE power jacks, that doubles up the 12V, both ground and positive. But that would require a new board design. so I will wait till the Connecter burns off the board.
May 07, 2013 07:19AM
Connectors usually haven't a maximum wattage, but a maximum current. So you get double wattage at the same current or half the current at the same wattage.
OK, there's also a maximum voltage rating, but that's 250V for the disk power connectors, far above both, 12V and 24V.
May 13, 2013 12:51AM
If the 12V connector is properly soldered to the board, you may actually have a problem with the power supply's connector (the female end), or with the actual connection its self.
Have you tried using a different socket from your power supply?
May 28, 2013 06:12PM
There is no point fiddling with 2 resistors and jumper and stuff just to make the 24v resistor compatible for led. The If led current is an absolute max rating, worst case scenario, not a minimum, nor something to aim at. Rather something to aim just below it with some safety margin. Simply make the resistor for whatever current it needs for 24v (a little downrating like 90% of max value). Then at 12v, the led will work with same resistor, although will have less current which means is going to light up less, but it still going to provide an indication.
There is no point maxing out the current in the led unless its a power led where the luminous flux matters. But if its just an indicator led, nobody is going to interrogate prisoners with this led in their face, or read books with it, so doesnt matter how bright it is. If it gets just a few mA and it lights up just a notch, its enough to provide an indication that the current passes there and thats all it has to do.
Edit:
But again, 24v wouldnt be exactly the top voltage, that would probably be the lowest between the voltage regulator max and the stepper drivers, probably around 32V so it doesnt get too close to max values (head room for ripple and spikes).
Oh i forgot but also mosfet max DS or breakdown might be a concern, i think some have 30v Vbr so should keep away from that to avoid it leaking, so perhaps 24v is a better maximum than i previously thought.
Edited 2 time(s). Last edit at 05/28/2013 07:20PM by NoobMan.
June 11, 2013 07:20AM
Here's a hack to make a Gen7 (any version) compatible with these early DRV8825-based "Pololus":
This light blue line is an additional track which can be done with a simple solder blob on the real board. It pulls Reset & Sleep always up, a feature missing on these stepper drivers.
That said, Pololu has replaced these early ones already with a version which fixes exactly that: [www.pololu.com]
P.S.: this blob is required for each of the four stepper drivers.
Edited 1 time(s). Last edit at 06/11/2013 07:21AM by Traumflug.
open | download - Bahn für DRV8825.png (9 KB)
June 12, 2013 04:01PM
Hi all, i'm in the process of starting my gen 7 ...i just ordered form traumflug.. i'm interested in Xoan's GEN7S's design and i tried to find the redrawn copy of the Gen 7 with the SD on board by Pete but i couldn't find it..has it been posted somewere?
June 16, 2013 05:46PM
First of: I'm new in this forum. I'd like to thank all the poeple around hwo developed RepRap's.
As the initiator of the forementioned patch Traumflug presented I'd like to suggest other mods.
Traumflug encouraged me to publish my ideas, so I do.
1. Please reroute the traces underneath the SMD-chip. Since we do not have soldermasks you may run in to shortage after soldering the chip.
2. please make 4 holes in the midle of the board. This will be usefull to mount a big heatsink providing improved cooling for the Pololu-drivers.
3. Here are pics of my first version of a dualprofil heatsink.
Two bars clamped together holding the 4 Pololu-boards in the middle with the help of a screw and a spring.
file.php?181,file=15954,filename=dual_prfile.php?181,file=15955,filename=heatsin
This build is not finished jet. I'm awaiting thermal pads and foils to complete the build.
Any hints appreciated.
Edited 8 time(s). Last edit at 06/16/2013 06:40PM by Peter_s.
open | download - dual_profile_heatsink.jpg (98.4 KB)
open | download - heatsink_attached_sm.jpg (105 KB)
June 16, 2013 06:04PM
There is no way to made the trace you show whithout run into a DRC violation.
June 16, 2013 06:32PM
Hi Xoan.
What about shifting the chip upward a little? This will help smoothing some traces too.
You may consider moving the capacitors too or choose the next size (5mm or 7,5mm raster).
Edited 1 time(s). Last edit at 06/16/2013 06:43PM by Peter_s.
June 16, 2013 06:41PM
> Hi Xoan.
> You may consider moving the capacitors too.
The problem is the trace passing between the pads of the same capacitor. This couldn't be solved by moving whatever component in the board smiling smiley
