Generation 7 Electronics Development October 12, 2010 12:33PM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Generation 7 Electronics Development October 13, 2010 05:07PM |
Re: Generation 7 Electronics Development October 14, 2010 05:02AM |
The ATmega644 may run out of speed if using 1/16 microstepping on all 4+ steppers, you want to make sure it can run steppers faster for the future and high resolution so maybe think about using the new Mega 2560 or better.
Think about having 2 x Extruders as standard, you don't have to populate the components on the PCB if you don't need the 2nd ext, but it's going to be a pain if it's missing.
Re: Generation 7 Electronics Development October 14, 2010 11:27AM |
Re: Generation 7 Electronics Development October 14, 2010 11:40AM |
Re: Generation 7 Electronics Development October 14, 2010 11:48AM |
Re: Generation 7 Electronics Development October 14, 2010 03:01PM |
peer
time-sensitive stepping-stuff.
Nudel
why use the bulky ATX20 connector in the first place? If a standard connector is needed, why not use the 4pin molex plug to get 12v,5v and ground?
Re: Generation 7 Electronics Development October 14, 2010 03:16PM |
Re: Generation 7 Electronics Development October 14, 2010 03:50PM |
Re: Generation 7 Electronics Development October 14, 2010 04:14PM |
Re: Generation 7 Electronics Development October 18, 2010 12:44PM |
Re: Generation 7 Electronics Development October 18, 2010 06:02PM |
Traumflug
I fear we're pretty limited here, as all ATmega processors are 8 bit, running at 20 MHz max. The Mega 2560 gives a lot of room for firmware, but it can't make steppers running faster. Moving to an entirely different processor like the AVR32 or AMD Cortex should be postponed until this PCB replicating thing works, IMHO.
Re: Generation 7 Electronics Development October 18, 2010 08:14PM |
Re: Generation 7 Electronics Development October 18, 2010 08:23PM |
Re: Generation 7 Electronics Development October 19, 2010 04:39AM |
I changed the config of the endstop connectors, so there is no need for wire bridges for these.
Re: Generation 7 Electronics Development October 19, 2010 04:44AM |
Re: Generation 7 Electronics Development October 19, 2010 02:01PM |
Re: Generation 7 Electronics Development October 19, 2010 02:23PM |
Re: Generation 7 Electronics Development October 23, 2010 08:43PM |
Re: Generation 7 Electronics Development October 24, 2010 04:17AM |
Re: Generation 7 Electronics Development October 24, 2010 05:45AM |
Why would it need RTAI for a pure conversion task?
Re: Generation 7 Electronics Development October 24, 2010 08:01AM |
Re: Generation 7 Electronics Development October 24, 2010 08:20AM |
Re: Generation 7 Electronics Development October 24, 2010 07:44PM |
Re: Generation 7 Electronics Development October 26, 2010 05:49AM |
Admin Registered: 17 years ago Posts: 1,791 |
Re: Generation 7 Electronics Development October 26, 2010 12:07PM |
Re: Generation 7 Electronics Development October 28, 2010 05:56PM |
Re: Generation 7 Electronics Development October 28, 2010 08:50PM |
Re: Generation 7 Electronics Development October 29, 2010 02:50AM |
Re: Generation 7 Electronics Development October 29, 2010 06:05PM |
