Re: Generation 7 Electronics Development August 16, 2011 05:19PM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Generation 7 Electronics Development August 17, 2011 02:48AM |
Re: Generation 7 Electronics Development August 17, 2011 05:32PM |
Re: Generation 7 Electronics Development August 18, 2011 07:05AM |
Re: Generation 7 Electronics Development August 18, 2011 08:11AM |
Re: Generation 7 Electronics Development August 19, 2011 02:51AM |
Does it Shutdown or enter in low energy consumption/sleep mode?
Re: Generation 7 Electronics Development August 25, 2011 06:06AM |
Re: Generation 7 Electronics Development August 26, 2011 08:15AM |
should the atmega get hot?
Re: Generation 7 Electronics Development August 26, 2011 09:10AM |
Re: Generation 7 Electronics Development August 27, 2011 08:06AM |
Re: Generation 7 Electronics Development August 29, 2011 04:51AM |
Re: Generation 7 Electronics Development August 29, 2011 06:02AM |
Re: Generation 7 Electronics Development August 30, 2011 03:42AM |
Re: Generation 7 Electronics Development August 30, 2011 05:32PM |
Re: Generation 7 Electronics Development August 31, 2011 04:20AM |
Re: Generation 7 Electronics Development September 13, 2011 05:29PM |
Re: Generation 7 Electronics Development September 18, 2011 07:53AM |
Re: Generation 7 Electronics Development October 12, 2011 03:59PM |
Re: Generation 7 Electronics Development October 13, 2011 04:48AM |
Re: Generation 7 Electronics Development October 13, 2011 07:57AM |
Re: Generation 7 Electronics Development October 14, 2011 01:55AM |
Re: Generation 7 Electronics Development October 25, 2011 09:11AM |
/* * define CPU frequency in Mhz here if not defined in Makefile */ #ifndef F_CPU #define F_CPU 7372800UL This Line confuses me as this value should either be 16000000UL or 20000000UL Or is there some kind of calculation required that is applied to the xtal frequence first.? #endif
Re: Generation 7 Electronics Development October 25, 2011 06:08PM |
Re: Generation 7 Electronics Development October 26, 2011 05:40AM |
BodgeIt
I am confinced I read something here about a new boot loader for the 20mhz version of Gen7 board
/* * define CPU frequency in Mhz here if not defined in Makefile */ #ifndef F_CPU #define F_CPU 7372800UL This Line confuses me ...
kenneth kneebone
so, i saw you put stories of people who successfully used gen7 on your gen7 page,do you know what software/firmware they used?
kenneth kneebone
you can upload the firmware[with gen7 adjustments] straight from arduino software, then it stays on the bord,right? *then* you can shut arduino and load reprap host,or replicatorg,right?
Re: Generation 7 Electronics Development October 26, 2011 02:28PM |
Re: Generation 7 Electronics Development October 26, 2011 05:44PM |
the baud rate should be 19200 right?
Re: Generation 7 Electronics Development October 26, 2011 06:32PM |
Re: Generation 7 Electronics Development October 27, 2011 07:10AM |
Looking at the 1.3 schematics it seems that only a +5V and Arduino sensor input are used.
(top pin and middle pin on the Gen7 1.2 PC
Re: Generation 7 Electronics Development October 27, 2011 07:25AM |
Re: Generation 7 Electronics Development October 27, 2011 02:27PM |
