Re: Generation 7 Electronics Development
October 28, 2011 06:21AM
Did you use the FiveD from Gen7's wiki page?
If yes, you'll have to review pins.h and make change
#elif MOTHERBOARD == 1
#ifndef __AVR_ATmega644__
#error Oops!  Make sure you have 'Sanguino' selected from the 'Tools -> Boards' menu.
#endif
to
#if defined __AVR_ATmega644__ || defined __AVR_ATmega644P__
#endif
That said, I'm not exactly an expert on FiveD, I'm working a lot more with Teacup Firmware.
October 28, 2011 07:21AM
Finch, i got the same error when i tried to compile that , did you use fiveD?
but then itried this other version of fiveD,seems to compile but i still dont know if its fully right.
[see attachment]
open | download - FiveD 20100610 for Gen7 v1.zip (55 KB)
October 28, 2011 07:36AM
this is odd,but on the one i downloaded,changed as per Traumflug's instructions,and posted,it says:
#endif
........and compiles without errors,
but if changed to:
#endif
it shows the error Finch got[and i got from the other version]
October 28, 2011 08:02AM
this is odd
Indeed!
Now, I simply messed up. You want the Oops not when one of both processors is present, but exactly the opposite.
Simply delete this section:
#endif
This section is a safety measurement only, it produces no code, it doesn't alter how the firmware works.
The correct line should be
#if ! defined __AVR_ATmega644__ && ! defined __AVR_ATmega644P__
, but it's always a bit error-prone to suggest something without actually trying it.
October 28, 2011 09:16AM
oh,ok,
other thing i wondered was: replicatorG and repsnapper still think its not connected,[i checked the com port etc]
will it connect without the opto endstops and all pololus connected to it?
I try traumflug file but its the same. So I download the test firmware for gen7 from wiki and it seem that something doesnt work. I click upload and it doesnt move from the situation on picture.
[www.shrani.si]
Is maybe something wrong with usb-ttl adapter (I bought it from ebay...cheap one). I tried with reset pin conected and disconnected. Everything is the same as in pictures. All these things are new for me so I have a lot of problems...Thank you!
winking smiley
[www.shrani.si]
[www.shrani.si]
October 29, 2011 03:46AM
Yes. Look at what G-code is exchanged and if your host can't do that, try pronterface, part of printrun.
OK, that precisely describes what happens. Change something and it will work.
smiling smiley
Did your ATmega come with the SetupTest firmware loaded? If not, try with that first: [reprap.org] . SetupTest shows results without all that host software fluff, so you can actually see what's happening instead of getting generic messages.
November 08, 2011 12:24PM
thanks Traumflug,pronterface works,now i just have to check the stepper motor wirings, are they the same as for other generations? is there a reference/diagram of how they wire up,or is it the standard reprap one[the instructions are for nema23]
November 09, 2011 04:16AM
Steppers are always wired the same, independent from size or other specifications. One coil to the left pair of the four pins, the other coil to the other pair.
November 11, 2011 04:02PM
An unnamed person
got a quick question reference the wiring of my Gen 7 electronics!
I'm just at the stage of connecting my axis endstop switches and just wanted to confirm if the below was correct?
Pin 1 (ATmega) - NC contact on switch
Pin 2 (Ground) - Common on switch
Pin 3 (+5V) - NO contact on switch
Pinout is right, with pin 1 being the one closest to the interrupter. These comments however ... an opto endstop isn't a switch. 5V and GND are static, while pin 1 flips between 4V and 0.2V, depending on wether the the interrupter is interrupted or not. 5V doesn't change and you also can't swap pin2 and pin3, like you could with a mechanical switch.
November 11, 2011 05:38PM
Traumflug
mechanical switch.
So basically a mechanical switch can't be used as an endstop with the Gen 7 Electronics, only Opto endstops!
November 12, 2011 06:24AM
Uh, that's not what I meant. Of course you can hook up mechanical endstops to a Gen7, just like to any other electronics.
I just said an opto endstop isn't entirely like a mechanical switch. One of the differences is, you can't make an opto endstop with a normally 5V signal from an endstop with a normally 0V signal by just swapping some pins. Where "normally" means: the interrupter fork is open.
November 16, 2011 07:25PM
git
Date: Sat Oct 29 19:56:15 2011 +0200
Board: remove tha ability to feed 5 V through the serial connector.
This is not of much use and had the unfortunate side effect of
destroying the USB-TTL converter while plugging improperly.
Hi, what about users that are connecting their gen7 to standard serial port via max232 based boards? +5V pin in serial connector was best way how to get power for it.
November 17, 2011 04:54AM
That works? Why is there no wiki description for that?
November 17, 2011 07:26AM
Yes. This kind of setup is common in MCU world, I am using it for all my PC-MCU communication, gen7 is no exception. It works well.
November 18, 2011 05:46AM
OK. So you feed everything 5V through the serial connector and just 12V on the Molex 4-pin in the upper left corner?
A bit a description in the wiki would be kind, so others can learn on how to set this up. ... and developers are aware such a setup works.
November 18, 2011 01:58PM
There's a description of the max232 circuit used for Darwin here
[reprap.org]
It is basically just a voltage level converter. Takes +,- 9 V and turns it into 0,5V TTL voltage levels. I think -9V becomes 5V and +9V becomes 0V but I could have that backwards. The max232 chip requires 5V supply to function. It is a simpler and likely more reliable way to do serial comms if you have a real serial port. But with the USB to serial cables being so cheap, it might not save you much money.
November 19, 2011 05:31AM
> upper left corner?
No, its not possible to get reliable power from PC serial port. I am using option 1 setup, but I have both "ATX24" and "Serial" jumpers shorted (thus breaking "You may jumper one, and only one of them." statement on wiki). This setup allows +5VSB from PSU to get to serial connector, so I can use it to power my max232 board attached there. max232 is just example, this can be usefull to anybody who needs to get standby power for his custom board attached to serial connector. Also please note, so currently there is no other way how to get +5VSB from PSU to aux. boards. MISC connector even lacks GND.
I prefer to disscuss and make it clear here first before editing wiki to avoid confusion.
Edited 1 time(s). Last edit at 11/19/2011 05:33AM by miso.
November 19, 2011 05:49AM
So you use 5VSB to supply your converter board.
The Misc connector is currently in the process to be extended to an extension board connector, which will have 5V, 5VSB, GND and the serial lines, so it'll be trivial to put a MAX232 there.
That said, I'd love to see a built in USB connector on the main board, but implementing this with an ATtiny is not so trivial and perhaps won't make it into the next release. One question to answer is: can communications go through SPI instead of serial.
November 22, 2011 01:00PM
i wonder has anyone got a working build of teacup on windows that they would be willing to upload? ive got one mostly working,it would be cool to have a look at what works though.
November 22, 2011 05:00PM
Download the Github version? The Teacup maintainer and the Gen7 maintainer is the same person, Teacup development is currently happening on a Gen7, which means, each patch is tested on a such before it hits the public repository.
If you'd be a bit more specific about what's not working, someone might be able to help.
That said, there's a thread for discussing Teacup: [forums.reprap.org]
November 22, 2011 06:38PM
ah,ok, thanks.
i downloaded the github version,couldnt get it to run,so googled other peoples versions and found this guys one: [lars.roland.bz]
it does seem to work,pronterface connects and can manually nudge the motors,but not print files for some reason.
November 23, 2011 05:28AM
Thank you for this helpful analysis.
November 25, 2011 08:08AM
Sorry for delay, I was quite busy last week.
Yes.
Why? What`s wrong with current setup?
PS: I have added note to wiki.
November 26, 2011 03:56AM
This Sparkfun plugin board isn't replicatable and much more expensive than an ATtiny45 (EUR 0.85).
November 26, 2011 06:28PM
I think so FT232`s cost under 4e, but one may consider this to be cost for "doing it right". While most of bit-banging MCU implementations fall more into "works by accident" category. They can work on one PC but not on other, because they dont obey USB specification. Take Gen7 with option 3 power from USB as example. You have there one 100uF capacitor still connected in circuit while USB spec. allows only 10uF, thus it may work with one host controller/hub but another may disconnect/reset port bacause of overcurrent.
But even if you manage to put "proper" USB on board, why to abandon current modularity? Why not let users to choose which converter board (sparkfun, ATtiby, max232, ...) to use to communicate with PC?
November 27, 2011 03:40AM
Thanks for pointing this out. The 100 uF can be replaced, of course.
What's the point of this modularity if the cheapest solution works fine for everybody? Having options just for the sake of having options is, well, the best way to make something more complex, expensive and error-prone than neccessary.
November 28, 2011 05:39PM
That's funny because mine seems to work better when powered from USB (option 3). I get more reliable firmware uploads and less hangs while printing. Of course this is from a fairly short test history as I've only been printing for a few days.
December 03, 2011 03:16PM
Cheapest: Actually, for majority of current users cheapest solution would be current (modular) solution, because if they choose to upgrade they will need to pay for ATtiny & friends while their ftdi boards will be laying useless in drawer.
Works fine for everybody: Somebody, especially someone using mains power for heated bed, may want to put optocouplers on communication lines between PC and reprap. Its much easier to put them on TTL than USB lines.
error-prone: expect same when you replace proven, working design with something new.
That said, reprap isnt final product, (at least some) users like to upgrade it and modify it, modular design greatly enhances this ability. Modular design also simplifies troubleshooting "on place", while modularity costs here only two 6 pin connectors. I admit, this is just my POV, someone else may consider USB on board to be a killer feature, but wouldnt this kind of user already choose some more "final product" style of electronics? Do you want to directly compete with them or provide alternative?
