So where are we in 2018? June 22, 2018 07:48AM |
Re: So where are we in 2018? June 22, 2018 08:02AM |
Admin Registered: 15 years ago Posts: 7,337 |
Re: So where are we in 2018? June 22, 2018 09:41AM |
Admin Registered: 18 years ago Posts: 14,181 |
Re: So where are we in 2018? June 22, 2018 09:48AM |
Re: So where are we in 2018? June 22, 2018 01:28PM |
+Mikie
As above, with respect to new genuine open source community-supported 32bit controllers?
The only board I see represented here seems to be Gen7, and it too seems to be dead-ish. Having a single extruder may have something to do with it. Even the ancient RAMPS had provision for two, and I thought we were supposed to go forward and not backward?
+Mikie
... Arduino really screwed up the Due with their choice of processor...
+Mikie
Other than that, heavily-advertised and talked-up Duet and Smoothie seem to be the only options with some support and user base. Personally, I'm not interested for several reasons, the least of them being the price. Yes, I know - support you get with it needs to be paid for, but it kinda beats the "community" aspect of it. But to each their own.
+Mikie
So, what's left? A pile of Chinese knockoffs, in many cases with open or hidden flaws. AZSMZ, Lerdge, AZTEEG, Re-Arm, MKS... Cheap to begin with, but later on - who knows?
+Mikie
On the DIY side, lots of separate people or groups doing the research and coding separately on LPC and STM processors, and who knows on what else. Industrious, but no real genuinely community-accepted results and mass use. Nowhere near like RAMPS in its' day.
+Mikie
So where are we? Is there a board being developed that could take over RAMPS' crown, or are we going to be forever stuck with commercial offerings?
Re: So where are we in 2018? June 22, 2018 01:37PM |
Re: So where are we in 2018? June 22, 2018 03:06PM |
Dust
dc42
although we don't advertise the Duet
BS! you mention it every single darn post you make, regardless of the topic, you bend the question so that the answer is the duet, That is advertising!
Re: So where are we in 2018? June 23, 2018 01:20AM |
Re: So where are we in 2018? June 23, 2018 03:16AM |
Re: So where are we in 2018? June 23, 2018 04:06AM |
Dust
@dc42
putting it in your signature is still advertising.
Re: So where are we in 2018? June 23, 2018 04:48AM |
+Mikie
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: So where are we in 2018? June 23, 2018 05:11AM |
+Mikie
Maybe time to ping Traumflug to blackm... PERSUADE him into switching to a better processor and add a 5th motor driver.
Re: So where are we in 2018? June 23, 2018 08:54AM |
Traumflug
I thought about using one of the dual core ESP32 boards as CPU. There's no shortage of variants: [esp32.net]. One core for doing WiFi, the other core for controlling the printer. Cores are said to be independent, so it could work out to have running one of them running timer driven (for steppers), the other one event driven (for the user interface).
But who'd write the firmware? Me certainly not.
Re: So where are we in 2018? June 23, 2018 12:23PM |
dc42
If you are looking for a board that integrates a good 32-bit CPU that you could either mount on another board or plug a shield on to, there's no shortage of evaluation boards from the major microcontroller manufacturers. For example, for $37 you can get this [www.digikey.com], a high-end board with an ARM Cortex M7 processor, SD card socket, Ethernet, and lots of I/O pins. RepRapFirmware has already been ported to it.
Re: So where are we in 2018? June 23, 2018 08:48PM |
Re: So where are we in 2018? June 24, 2018 11:04AM |
Re: So where are we in 2018? June 24, 2018 01:56PM |
Re: So where are we in 2018? August 14, 2018 03:07PM |
Diggrr
Azteeg (Panucatt Devices) is in Irvine California, not China, not a clone.
I've found the boards and drivers to be quite well made, but support for hardware and firmware is sketchy at best...your Google-Foo must be black-belt or higher. Seriously.
Re: So where are we in 2018? August 14, 2018 05:30PM |
Modmike
Diggrr
I will second that. I recently spent some time with the Re-Arm, Azteeg X5 Mini Wifi, and Azteeg X5 GT. They re all great buys but I really like the X5 Mini Wifi. It is incredibly affordable, $110 USD with 4 removable TMC2224 (TMC2208) drivers.
I just finished adding it to Marlin, and best part is it has an onboard 8266 that has a Web UI THAT WORKS WITH MARLIN! I also did a pin configuration for all of them that supports a single stock cable connection the CR-10 stock LCD.
The only shortcoming of the mini wifi is that lack of driver expandability for multi-material. I think they have a new version coming with more drivers that will replace the X5 GT. Also used the re-arm for a few months and that's a great upgrade if you have a ramps board.
I have the Duet Wifi and Duet X5 as well but for my money, I think Panucatt is where its at right now.
Re: So where are we in 2018? August 15, 2018 02:46AM |
