Gen7 build: July 05, 2011 04:05AM |
Re: Gen7 build: July 06, 2011 07:56AM |
Re: Gen7 build: July 23, 2011 04:17PM |
Re: Gen7 build: October 28, 2011 03:33PM |
Re: Gen7 build: October 29, 2011 03:36AM |
Is the standby led lit only when you are using ATX connector?
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Gen7 build: October 30, 2011 12:22PM |
Re: Gen7 build: October 30, 2011 01:00PM |
[www.flickr.com]
Re: Gen7 build: November 05, 2011 08:52PM |
Re: Gen7 build: November 08, 2011 02:56PM |
http://www.ebay.co.uk/itm/370532286388?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649I am currently hitting the "upload to IO board" button and nothing is happening...
Re: Gen7 build: November 09, 2011 04:13AM |
Re: Gen7 build: November 09, 2011 01:42PM |
Re: Gen7 build: November 10, 2011 05:34AM |
Does this mean that the TXD and RXD are marked out wrong on my cheap eBay TTL chip?
Does anyone know how to connect my zapp automation motors to the gen7 board?
Re: Gen7 build: November 10, 2011 03:58PM |
Re: Gen7 build: November 11, 2011 03:54PM |
Re: Gen7 build: November 11, 2011 04:06PM |
Re: Gen7 build: November 12, 2011 12:30PM |
Re: Gen7 build: November 13, 2011 01:12PM |
Re: Gen7 build: November 14, 2011 04:58AM |
Re: Gen7 build: November 17, 2011 09:13AM |
Re: Gen7 build: November 18, 2011 05:39AM |
Re: Gen7 build: January 03, 2012 05:28PM |
Each Pololu has a trimpot located next to the heatsink. The trimpot controls the current that is sent to each motor. Turning the trimpot counter-clockwise reduces the current to the motor, turning it clockwise increases the current to the motor. Start by adjusting the trimpot down until your motor vibrates on the spot rather than turning cleanly. Now turn the trimpot in a clockwise direction in small increments (1 eighth of a turn) until the motors just start running. Then give the trim port a final turn of about 1 eighth of a turn and your should be good to go.I think this is a very handy tip for anyone with jumping stepper problems
