Gen 7 pin allocations July 12, 2011 01:44AM |
Re: Gen 7 pin allocations July 12, 2011 03:59AM |
Looking at the pin usage it seems there are some pins used for limit switches that will interfere with the SD card's SPI interface.
Finally what is the fan output used for?
Does anyone know any reason for not allocating these pins to my desired extra functions.
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Gen 7 pin allocations September 11, 2011 03:05PM |
Re: Gen 7 pin allocations September 12, 2011 03:18AM |
Myke Predko has solved LCD connection using only 2 wire:
[www.rentron.com]
3. I recommend to add GND and VCC to that currently unused extension header (pins 16-20 of CPU).
Also tracks and pins for LM7805 regulator would be nice to have at least as option
I mean that +5V for stepper controllers could also be alive all the time
6. Also MOSFET gates needs to have pulldown resistors
Re: Gen 7 pin allocations September 12, 2011 05:58AM |
Re: Gen 7 pin allocations September 12, 2011 11:13AM |
Re: Gen 7 pin allocations September 13, 2011 07:10AM |
Your example of SD card pins sharing (or what), does it mean that both processors (if stacked card has a processor) could or should controll same SD card? That sounds not good.
Concerning second stepper: could it be best if original Z stepper is reconfigured to drive that second extruder?
If SDRAM is possible to get operational using MISO, MOSI, SCK and maybe pin 40 for CS (has anybody done it yet?)
> You apparently moved miscrostepping jumpers more
> to the top, between Pololus and motor connectors.
No, those 4 pin rows are for optional pin strip stepper connectors just like RAMPS had.
Half stepping is lost. Does anybody really uses it?
On that scheme also termistor exitation is feeded from AVCC
That attached PCB planning idea was routed using 32 mills tracks and about 22-25 mills clearings.
Re: Gen 7 pin allocations September 20, 2011 01:27PM |
Re: Gen 7 pin allocations September 20, 2011 02:30PM |
Re: Gen 7 pin allocations September 20, 2011 05:23PM |
Re: Gen 7 pin allocations September 20, 2011 06:08PM |
Re: Gen 7 pin allocations September 15, 2012 07:21AM |
Re: Gen 7 pin allocations September 16, 2012 05:03AM |
Re: Gen 7 pin allocations September 17, 2012 10:11AM |
Re: Gen 7 pin allocations September 18, 2012 05:58AM |
If you'd prefer, I can open a new thread with my suggestions?
Rather than forking, it makes more sense to incorporate changes.
- AVR-CDC for USB-TTL (I have a tested working implementation)
Re: Gen 7 pin allocations September 18, 2012 06:16AM |
Re: Gen 7 pin allocations September 18, 2012 08:08AM |
The ATtiny 45 only supports 4800 Baud.
it's in Eagle
Personally I vote for integrate
Re: Gen 7 pin allocations September 18, 2012 08:12AM |
