Acetone : ABS as ? : PLA
Posted by John Meacham
October 08, 2012 07:03PM
One of the nice things about printing with ABS was that ABS dissolves pretty much completely and easily in acetone, which is cheap and easy to get anywhere. It made things like cleaning a jammed nozzle trivial. Just drop the hot end in acetone and you are done. Plus, the ability to create "ABS glue", a mixture of ABS and acetone is just so handy. It will bond ABS to ABS as if they were a single part.
Now. PLA does weird things in acetone
[hydraraptor.blogspot.com]
but is there some solvent with similar properties that works on PLA? It would be a very useful thing.
Re: Acetone : ABS as ? : PLA
October 10, 2012 06:01PM
Here you go.
Short of fire, thats the closest "solvent" I know of that works with PLA. To make it yourself...
Be warned that the following chemicals are all dangerous, so handle them with care and with the proper safety precautions!
* Propan-2-ol
* Potassium hydroxide
* Aluminium hydroxide
We used technical propan-2-ol (98%) but you can also use pure propan-2-ol, 8.3% Potassium hydroxide (w/w) and a small catalytical amout (<1%) of Aluminium hydroxide.
A short manual how to prepare the “BetaSolution”:
For preparing the solution we gently warmed up the technical propan-2-ol in a waterbath to a temperature of about 40-50 °C. Be sure, the flask containing the propanol is not completely closed because of the rising vapour pressure. We used a flask made of glass with a perforated cap to prevent condensation of water and evaporation of propan-2-ol. After this, we took the flask out of the waterbath, dryed it from the outside, removed the cap and put the Potassiumhydroxide into it in small quantities. After each portion we stirred. The last little portion consists of about 0.5 g aluminum hydroxide which should also dissolve.
The solvatation of potassium hydroxide and aluminum hydroxide in propan-2-ol needs time. You generate a saturated solution, so don’t wonder, if it gets cloudy after cooling or takes much time to dissolve completely.
Store the resulting solution safely, out of reach of children in a glass container at a dry and cool place. If you use a plastic flask it might deform or the solution will react in another way with the flask.
For use, pour a small amount into a glass, so that your object is completely submerged in the solution, and wait for the PLA to be dissolved. Please only do this in a well ventilated area or outside, because the solution will give of flammable fumes. Dont smoke while doing this !
If you want to speed up the dissolving process, you can warm the solution with a water bath (NO open fire), and stir it with a ultrasonic cleanser or manually with a spoon. This will greatly improve the speed of the dissolving.
Please wear gloves and glasses when handling the warmed solution. It is as aggressive as drain-cleanser!
After dissolving the PLA you should wash your 3D-model with much water. We recommend to put it into another flask containing pure water and let it stand there for another hour. After this, you can dry it on air or with a hair blower.
The solution shouldn’t be disposed into drain without dilution! Let it cool to room temperature, if warmed, and gently put small quantities into a 5 times bigger amount of water. Now you can easily use it as drain-cleanser!
For added information, you can download a safety datasheet we preprared from here
Also we are now opening an onlineshop, www.2printbeta.de, where we plan to sell this solution and other reprap related parts after we get the neccessary permits from the government. So if you are in europe, stay tuned to get the BetaSolution directly from the inventors.
When releasing in december, we also provide a more detailed german and english manual how to use BetaSolution.
To the DIY community:
Have fun with the developement of a smart software to create suitable support structures! Have even more fun with printing and dissolving the generated two-component-objects to obtain a clean ABS structure with overhangs and bridges as much as you want!
-Tom
