Photopolymer resin's stamp cutting
Posted by Koolvidz
April 20, 2016 12:36PM
Hi every one .. Recently i started cutting photopolymer resin stamps that I make using laser cutting machine. After the cut they turn yellow. Im unable to understand why. Is there some other technique to cut photopolymer stamps to shape ?
Looking forward to some positive suggestions.
Thank you in advance.
Vidushi
VDX
Re: Photopolymer resin's stamp cutting
April 20, 2016 01:09PM
Hi Vidushi,
what wavelength has your laser?
Colour changing shows some "post-curing" with chemical reactions caused by heat or light energy (mostly with UV or blue) - or by fumes, if not vented properly or cut with too much energy in a CO2-lasercutter.
Cutting without embedding any heat or chemical energy can be done by milling, waterjet-cutting or with an oszillating needle ...
Viktor
April 20, 2016 01:13PM
Im not really sure of the wave length of the laser as im outsourcing it .. After curing it is perfect and almost clear .. But when i cut them in shape using laser machine they turn yellow. Could you suggest what wavelength should I be using ? Or any other method that would help me with precision cutting around my deisgn ?
VDX
April 20, 2016 01:48PM
... is the laser beam visible or invisible?
If the beam is invisible (only the burning spot shines yellow-white), then it should be a CO2-laser with 10640nm (or a NdYAG-laser with 1064nm ... or a fiberlaser with 1070nm -- both not so common with lasercutters).
The cheap CO2-lasers are made with a long glass-tube and needs water-cooling, better ones are sealed in a aluminium box and cooled by forced air.
The other common types uses blue laserdiodes with 445nm with powers of up to 3.5Watts ... or UV-laserdiodes with 405nm, but powers below 1 Watt ...
Viktor
April 20, 2016 01:55PM
The laser beam is visible ..
I do not have water jet cutting in my city .. Is there any way I can cut these photo polymer sheets exactly where i want them to cut .. Because the have designs on them .. And i want it to be cut around the design.
VDX
April 20, 2016 03:04PM
Koolvidz
... is it blue or red?
If blue - is it a "strong blue" (then should be 445nm), or a "pale blueish" (then 405nm)?
... you can try with milling -- or, if the sheets are thin enough, then with a knife cutter ...
Viktor
