Suitable resin chemistries April 16, 2014 06:04AM |
Re: Suitable resin chemistries April 16, 2014 07:49AM |
Re: Suitable resin chemistries April 16, 2014 05:24PM |
Re: Suitable resin chemistries April 16, 2014 08:39PM |
Re: Suitable resin chemistries April 17, 2014 03:33AM |
Re: Suitable resin chemistries April 17, 2014 04:44AM |
Admin Registered: 16 years ago Posts: 13,873 |
Re: Suitable resin chemistries April 17, 2014 06:33AM |
Re: Suitable resin chemistries April 17, 2014 07:52AM |
Azrael511
UV epoxies, known as cationic UV systems, are also generally heated at the end of polymerization to help drive it to completion.
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Suitable resin chemistries April 17, 2014 07:59AM |
nastybyte
Is there any opensource development being done in this area?
Re: Suitable resin chemistries April 17, 2014 12:42PM |
Re: Suitable resin chemistries April 24, 2014 05:11PM |
Re: Suitable resin chemistries April 25, 2014 03:02AM |
Re: Suitable resin chemistries April 25, 2014 09:32PM |
nastybyte
a DLP printer would be much simpler, but would have a very limited build volume and also a definite limit to resolution.
nastybyte
There's one thing i don't understand: whether you're working from top or bottom, there will be times when you print at a point with uncured resin below/on top of the desired "pixel". Beam intensity will decrease exponentially, won't this result in a varying region of undercured material? How is this problem overcome, do you rely on the UV absorbance of the resin being high enough that this region will be negligible?
Re: Suitable resin chemistries April 26, 2014 06:46AM |
A2
I've been looking into this more, and there is a new DLP-SLA technique where you can expose tiled portions of a much larger image with the same resolution 25microns X/Y.
A2
DLP-SLA build size with a 1920x1080pixels is 192mm x 108mm (7.5 in x 4.3 in) at 0.10mm resolution, which is as good, and possibly maybe a little better than the Shapeways ultra detail DLP-SLA printer.
I think that's a pretty big part considering you can go over 14.0 inches in the Z-axis.
A2
Disadvantages STL (laser)
1. Can be slow to cure a whole solid layer, and large object take longer to build than DLP-SLA.
2. Vibrations need to be isolated from the printing process or part geometry and surface finish will be effected.
3. Requires XY linear guides, i.e. more mechanics, and stepper motors required.
Re: Suitable resin chemistries April 26, 2014 09:26AM |
Re: Suitable resin chemistries April 26, 2014 09:53AM |
Re: Suitable resin chemistries April 27, 2014 06:40AM |
Re: Suitable resin chemistries May 16, 2014 10:09AM |
Re: Suitable resin chemistries May 26, 2016 09:06AM |
Re: Suitable resin chemistries May 26, 2016 10:44AM |
