Clear to white polymer/paint
Posted by MZDpolymer
September 25, 2012 12:24AM
New to the forum here. Cheers to engineers.
I'm looking for a polymer that will go from clear to bright white.
This can be through any reasonable pathway that is safe for consumers, for example:
-Heating
-UV treatment
The polymer can be in a monomer state to start with or already polymerized
Let me know if you have any ideas, thanks,
Mike
VDX
Re: Clear to white polymer/paint
September 25, 2012 03:01AM
... the easiest way to 'whiten' a clear plastic is to paint it white or to inject/create microscopic air-bubbles in the surface.
This 'foaming' could be achieved with a laser, that heats the surface to boiling but without cracking the polymer, or it will get yellow/brownish because of carbonizing - this can be made either with ultra-short pulses with a CO2-laser or with an UV-laser with a short enough wavelength, so it won't penetrate the clear body.
Another trick could be chemistry, where a solvent reacts with the polymer to create a micro-foam in the surface region ...
Viktor
Aufruf zum Projekt "Müll-freie Meere" - [reprap.org]
September 25, 2012 12:37PM
To clarify the application:
I need something that one could draw on like a canvas while it was see through and then the polymer substrate would be whitened to produce the final product that would be the painting against a white background.
Could you suggest a possible setup? i.e.:
Some polymer that would take paint on one side while it is clear and then would turn white on the other side when the user applies a specific solvent in a specific way.
Thanks,
Mike
