Autodesk has released its resin formula. (Via Makezine.com)
Autodesk Standard Clear Prototyping Resin for Ember (all percentages are wt/wt)
Oligomer: Allnex Ebecryl 8210 39.776%, Sartomer SR 494 39.776%
Photoinitiator: Esstech TPO+ (2,4,6-Trimethylbenzoyl-diphenyl-phosphineoxide) 0.400%
Reactive diluent: Rahn Genomer 1122 19.888%
UV blocker: Mayzo OB+ (2,2’-(2,5-thiophenediyl)bis(5-tert-butylbenzoxazole)) 0.160 %
IMPORTANT NOTICE: The Autodesk Standard Clear Prototyping Resin (PR48) is intended for professional use only. We are releasing the chemical formula for PR48 pursuant to the terms of the Creative Commons Attribution-ShareAlike 4.0 International (CC BY-SA 4.0) license. Working with this formula is at your own risk, and as a result, you are solely responsible for (a) complying with all applicable laws, rules and regulations and (b) any and all results and liabilities, including personal and property damage, arising in connection with such work. BEFORE you undertake any work with the formula, we recommend that you review carefully the safety warning notifications and the Material Safety Data Sheet for PR48 here. Autodesk expressly disclaims all warranties (including those attendant to the Autodesk® 3D Ember Printer) in relation to your creation, use or distribution of the formula.
Share on Facebook Share on Twitter 127 143 1
EmberOpen Source3D Printingresin
- See more at: [
spark.autodesk.com]
