Re: UV curing photopolymer for rapid prototyping August 15, 2012 06:06AM |
Re: UV curing photopolymer for rapid prototyping August 15, 2012 08:16AM |
Re: UV curing photopolymer for rapid prototyping August 21, 2012 09:16AM |
mo
Re: UV curing photopolymer for rapid prototyping October 23, 2012 07:10AM |
Re: UV curing photopolymer for rapid prototyping August 29, 2013 08:13AM |
Re: UV curing photopolymer for rapid prototyping November 25, 2013 01:01AM |
Re: UV curing photopolymer for rapid prototyping August 26, 2014 02:37AM |
Re: UV curing photopolymer for rapid prototyping December 11, 2014 04:32AM |
Re: UV curing photopolymer for rapid prototyping December 21, 2014 09:21PM |
Re: UV curing photopolymer for rapid prototyping January 26, 2015 01:03PM |
fungis
Hi mo,
I know this is fairly late. To increase cure in a UV curable resin normally you can achieve that by slightly modying to resin it self with faster curing monomers. Dpha is an example. Using PI closer to the visible spectrum will lead to an increased cost .Generally phosphine oxides will have some cure around there. So tpo bapo mapo, but bapo tends to be the more reactive. But as with everything it will take some experimentation to get it to where you want.
I have not worked with 3d printers before. But I do work for a UV curable ink company. Let me know if this was of any use to you.
Fungis
Re: UV curing photopolymer for rapid prototyping March 11, 2015 10:34PM |
