marlin armleven setup not clear
Posted by Macsimski
December 31, 2013 12:07PM
Hello all,
Im in the process of reutilising a mechanical arm used to place things ins a automated chemical machine. it has a arm with two steppers, wormwheel drive and a chain though the first arm to the second. very sleek. i will post pictures soon. it works like the reprap morgan or a scara arm.
but now the question.
I downloaded the marlin armlevel firmware from [github.com] and I want to fill in the proper information for my setup but I have no idea what is ment:
// Center-to-center distance of the holes in the diagonal push rods.
//#define DELTA_DIAGONAL_ROD 250.0 // mm
// Horizontal offset from middle of printer to smooth rod center.
//#define DELTA_SMOOTH_ROD_OFFSET 175.0 // mm
// Horizontal offset of the universal joints on the end effector.
//#define DELTA_EFFECTOR_OFFSET 33.0 // mm
// Horizontal offset of the universal joints on the carriages.
//#define DELTA_CARRIAGE_OFFSET 18.0 // mm
can anyone explain them?
(edit) i now understand that those values are for a true deltabot. mine is more like the morgan, although the secundary arm is operated trough a chain via the primary arm.
Edited 3 time(s). Last edit at 12/31/2013 01:50PM by Macsimski.
A2
Re: marlin armleven setup not clear
December 31, 2013 12:25PM
See if any of these links answer your questions:
...values you’ll need to change in Configurtion.h for the Marlin firmware designed for a Delta printer.
[trains.socha.com]
DELTA_EFFECTOR_OFFSET Question
[forums.reprap.org]
Rostock Mini Calculations
[forums.reprap.org]
I'm stuck: Trying to set up Diagonal Rod Arms
[forums.reprap.org]
Looking forward to seeing some pictures! smiling smiley
December 31, 2013 02:20PM
those ones look like delta values because for new drive systems is recomended to reuse it because of ram memory, look at comments to know what are they
I have modified Repetier firmware for my drive system, I havent tested yet but looks fine
Maybe I could help you if you want to adapt it
