Rather than hijack Mikes excellent thread, I thought I would start a new one.
I have been trying out a new Scara Dual (parallel) arm design and now at the point of testing.
The controller is Geetech T2560 and gets configured the same as the 7 = Ultimaker so using #define MOTHERBOARD 7
Ttsalo/Marlin-SCARA seems fine on the X-Y and Z-Axis and behaves as expected.
Now I moved onto Marlin FIVE_BAR firmware by Pavlo and set up the same settings to suit the controller board as I did in Ttsalo code.
But the machine goes crazy when you try and jog any Axis. If you hit Z jog the X and Y motors start spinning everywhere and then eventually stop and the Z-Axis attempts a move.
I have disable homing/limit switches while testing and extruder/heated bed.
One thing that occured to me is that the working code that Mike and PavloG both are configured for Ramps #define MOTHERBOARD BOARD_RAMPS_13_EFB
Has anyone else succesfully got the FIVE_BAR code working on another controller than Ramps ?
Cheers
Sean.
Edited 1 time(s). Last edit at 10/26/2015 05:44PM by CLaNZeR.
www.cncdudez.co.uk]
