S-maker: scara type desktop 3d printer prototype.
Posted by morphos
April 08, 2013 03:31PM
Hi.
I'd like want to share with you guys the development of a desktop Scara 3d printer that i have started a few weeks ago.
I call it (for now) the s-maker.
I have created a blog were you can learn a little more about it.
http://www.make-it-3d.eu
Here is a little video showing its first movement :
http://www.youtube.com/watch?v=bEMpOPl52wI
Please comment. Any feedback is welcome.
Re: S-maker: scara type desktop 3d printer prototype.
April 08, 2013 07:01PM
Very cool. With the motors powered and not moving does the end effector feel springy at all?
woo
April 09, 2013 06:24AM
nice and clean! beautiful
April 09, 2013 06:31AM
The assemble is quite rigid... will see if enough.
In fact, when i apply pression, what gives a bit is the wheel and not the arm.
The aluminium tubes are 12mm diameter and the joints are small and printed in PLA (more rigid than ABS).
But i'll have to conduct some more tests to see if it's rigid enought for printing.
I am fairly optimistic....smiling smiley
woo
April 09, 2013 06:35AM
how did you solved firmware issues?will it be open source?
VDX
April 09, 2013 07:20AM
... in the German forum someone suggested that you can rotate your setup, so the arm/head can glide on the bottom (ointing up) and the bed will move in Z.
So you can have any rigidity you want, but have to elevate the bed with the printed objects ...
Viktor
April 09, 2013 07:56AM
Really neat design and a very compact motor assembly. I am looking forward to how this one prints.
Helium Frog Website
woo
May 06, 2013 02:45AM
anything new here? smileys with beer
O Morphos parece que sumiu, alguem sabe dele?
August 23, 2013 07:30PM
Looks like very few parts are needed. Can you tell how many so far? How many printed?
A2
August 28, 2013 01:08AM
@morphos
Nice work!
What firmware, and microcontroller are you using?
A2
August 31, 2013 02:29PM
I like the static bed for scaling up to a larger build area. This seems like a design that could become an upside-down T, where a mobile bed drives itself into position, and then drives away with the printed part when done. smiling smiley
September 02, 2013 04:01AM
It's quite identical to Quentin Harley's RepRap Morgan, except that you move the head, while Quentin moves the bed.
I like the principle in your design as well as in Quentin's, because it has so much potential for expansions and improvements, while being inexpensive and simple.
Drawback in your design will be the reduced precision on mid levels of the print, because
- the weight of the arms will bend the z-axis-rods (slightly, but noticeable)
and
- the movement of the arms will cause more tremor on the z-axis.
What I like on Quentins design over yours (excuse me for that, nice work of yours anyway smiling smiley ) is the fixed place of driven components through the print and the reduced amount of moving masses. Only the platform moves up and down, what Quentin uses to balance the slight difference in toolhead-height between folded and unfolded arms (a point that you can integrate in your firmware with no changes to your design, by the way).
Nice build. I like scara robots. smiling smiley
October 13, 2013 11:05PM
Is there an S-maker machine or kit to be had?
Is it open source?
Where can one get one?
November 17, 2013 07:22AM
thats great design.....
January 12, 2014 09:35AM
Morphos !
Any comments?
