Re: Tri-Polar Bot Concept -- Meet Wally November 22, 2013 05:17PM |
Re: Tri-Polar Bot Concept -- Meet Wally November 22, 2013 05:44PM |
cdsteinkuehler
Can you weigh all the parts? I get 871 grams, including the support material for the xy forearm (calculated...I'm still printing some of the arms).
Re: Tri-Polar Bot Concept -- Meet Wally November 24, 2013 11:38AM |
Re: Tri-Polar Bot Concept -- Meet Wally November 25, 2013 11:14PM |
sgraber
I checked and my parts weighed 789 grams before support material. With support material, it was pretty close to 820 grams.
Re: Tri-Polar Bot Concept -- Meet Wally November 26, 2013 06:18AM |
sgraber
Re: Tri-Polar Bot Concept -- Meet Wally November 26, 2013 07:33AM |
cdsteinkuehler
sgraber
Shane: What nozzle size are you printing with, and what's your single-wall thickness? I'm using 3mm filament with a 0.5mm nozzle, so I've got perimeter extrusion widths of 0.50mm and infill widths of 0.70mm (according to Slic3r). I'm thinking my 3 perimeters is probably a fair amount thicker than your 3 perimeters if you're using a smaller nozzle.
Re: Tri-Polar Bot Concept -- Meet Wally November 26, 2013 08:07AM |
sgraber
I'm printing with a 0.4mm orifice and my best guess at wall thickness is somewhere around 1-1.5mm with 3 perimeters. Default extrusion width is set @ 0.5mm.
Re: Tri-Polar Bot Concept -- Meet Wally November 26, 2013 09:50AM |
cdsteinkuehler
sgraber
Thanks! I measured one of my many failed prints, and I get 1.7mm for the three perimeters. I'm guessing that's where my extra weight is coming from (or I've just got really heavy PLA!).
Re: Tri-Polar Bot Concept -- Meet Wally November 26, 2013 09:57AM |
sgraber
What's your % infill? How about solid top and bottom layers? I run 15% infill and 3 solid top/bottom layers.
Re: Tri-Polar Bot Concept -- Meet Wally November 26, 2013 10:14AM |
cdsteinkuehler
I'm running the same. My Slic3r config file is in the github repo for reference: [github.com]
That doesn't include my filament settings (2.90mm) and extruder details (0.5mm nozzle), but it's got most everything else.
Re: Tri-Polar Bot Concept -- Meet Wally November 26, 2013 10:18AM |
Re: Tri-Polar Bot Concept -- Meet Wally November 26, 2013 10:23AM |
cdsteinkuehler
Hmm...I like the honeycomb infill, particularly at low infill ratios (since all layers are supported), but I wonder if that's it.
I'll slice and print a couple arms with rectilinear and see what happens.
Re: Tri-Polar Bot Concept -- Meet Wally November 26, 2013 10:38AM |
sgraber
Just slice a single WALLY arm with Honeycomb and another with Rectilinear (both @ 15%) and compare print times and filament usage (filament usage information is at the very end of the gcode file).
Re: Tri-Polar Bot Concept -- Meet Wally November 26, 2013 10:49AM |
Re: Tri-Polar Bot Concept -- Meet Wally November 26, 2013 12:43PM |
Re: Tri-Polar Bot Concept -- Meet Wally November 26, 2013 03:37PM |
sgraber
FWIW if you want to compare your filament usage and print times, take a look at a page I setup for myself while I was making plates for printing for Smooshed:
Re: Tri-Polar Bot Concept -- Meet Wally November 26, 2013 03:43PM |
cratos
Is Wally usable at this point? I thought the kinematics were not finished?
If he is, how does he perform compared to a good cartesian bot?
- How is layer alignment (in the Z axis)? I find that layer alignment makes a massive difference in terms of perceived quality. Is the bed movement more consistent since it's just a pivot and no rods? Or does the math mean there is rounding error?
- How is the repeatability/slop/backlash/etc (x/y axis)? Do the arms flex/bounce/etc?
Re: Tri-Polar Bot Concept -- Meet Wally November 26, 2013 09:01PM |
Re: Tri-Polar Bot Concept -- Meet Wally November 26, 2013 09:17PM |
Re: Tri-Polar Bot Concept -- Meet Wally November 26, 2013 11:01PM |
nicholas.seward
The only thing that I have heard that is even remotely valid is that it is advantageous to pick layer heights that are multiples of a full step. You better believe you can do that with imperial or metric screws.
Re: Tri-Polar Bot Concept -- Meet Wally November 26, 2013 11:18PM |
Re: Tri-Polar Bot Concept -- Meet Wally November 27, 2013 01:24PM |
Re: Tri-Polar Bot Concept -- Meet Wally November 27, 2013 01:36PM |
Re: Tri-Polar Bot Concept -- Meet Wally November 30, 2013 03:15PM |
Re: Tri-Polar Bot Concept -- Meet Wally November 30, 2013 03:38PM |
Re: Tri-Polar Bot Concept -- Meet Wally November 30, 2013 04:44PM |
Re: Tri-Polar Bot Concept -- Meet Wally November 30, 2013 04:47PM |
Re: Tri-Polar Bot Concept -- Meet Wally November 30, 2013 04:50PM |
Re: Tri-Polar Bot Concept -- Meet Wally November 30, 2013 04:55PM |
smooshed
Since I don't have Inventor on my workstation at the moment, I've been using Inventor View (free, but windows only) to get a handle on how Wally goes together.
cozmicray
Is there an assembly drawing out there for Wally?
or
How to make one?
Left, right, top, front line drawing?
Re: Tri-Polar Bot Concept -- Meet Wally November 30, 2013 05:01PM |
