New polar concept/design December 17, 2013 04:11PM |
Re: New polar concept/design December 17, 2013 04:57PM |
Re: New polar concept/design December 17, 2013 05:20PM |
Dale Dunn
Straight lines passing near the table center are going to need very high angular velocity and acceleration.
I'm not sure if any firmware support this configuration. Will you be able to modify firmware to make this work?
You will have much greater chances of success building an established design, I think.
Re: New polar concept/design December 17, 2013 05:39PM |
Re: New polar concept/design December 17, 2013 05:42PM |
Re: New polar concept/design December 17, 2013 05:59PM |
see3d
Your arms are much like "Wally" arms, but vertical instead of horizontal. You may be able to adapt some of the design details proposed for Wally.
A2
Cut the table in half, and only use a half circle (save space), or add a second set of arms and print 2 parts at the same time.
Off set the arms from the center of the table to avoid the singularity.
It would be neat to be able to tilt the platen to print overhangs.
Re: New polar concept/design December 17, 2013 09:08PM |
Re: New polar concept/design December 17, 2013 10:48PM |
Re: New polar concept/design December 18, 2013 12:58AM |
if you give the correct angles to the arms, it keep in levelQuote
nicholas.seward
How do you plan to keep the effector level? I have a similar project bouncing around in my head but it is 4 degrees of freedom. I was going to use 3 proportional gear drive joints. [www.youtube.com]
if the print volumen is small it can be done in half plate... yes is not the best for 90° but the reason of using polar is the possibility of adding a 3d scanner in futureQuote
see3d
Printing with a full circle is great for certain things. A gear, a vase, a snowflake, and anything with a radial center point. Things made of 90 degree walls would print best on a Cartesian mechanism.
Re: New polar concept/design December 18, 2013 10:26AM |
Re: New polar concept/design December 18, 2013 10:58AM |
Re: New polar concept/design December 18, 2013 01:19PM |
Re: New polar concept/design December 18, 2013 02:22PM |
Re: New polar concept/design December 18, 2013 04:44PM |
Re: New polar concept/design December 18, 2013 05:49PM |
Re: New polar concept/design December 18, 2013 10:36PM |
Re: New polar concept/design December 19, 2013 02:19AM |
Re: New polar concept/design December 19, 2013 09:39AM |
Re: New polar concept/design December 19, 2013 09:41AM |
Re: New polar concept/design December 19, 2013 01:08PM |
Re: New polar concept/design December 19, 2013 05:23PM |
Re: New polar concept/design December 20, 2013 05:15AM |
Re: New polar concept/design December 20, 2013 03:15PM |
Re: New polar concept/design December 20, 2013 03:41PM |
Re: New polar concept/design December 20, 2013 06:41PM |
Re: New polar concept/design December 20, 2013 07:14PM |
Re: New polar concept/design December 20, 2013 07:39PM |
Re: New polar concept/design December 20, 2013 09:03PM |
Re: New polar concept/design December 20, 2013 09:41PM |
Re: New polar concept/design December 20, 2013 09:51PM |
