parallel scara inverse kinematics
Posted by ekaggrat
December 22, 2013 10:30AM
hi,
i am building a small robotic arm based on the parallel scara design ( some thing like the morgan ) , but i can't seem to find the equations for the inverse kinematics of this design... I know the equations for a serial scara robot..
Does anybody have any idea where i could find them ? Or any links to them
thanks
Edited 1 time(s). Last edit at 12/22/2013 10:31AM by ekaggrat.
Re: parallel scara inverse kinematics
December 22, 2013 06:44PM
if you share some images maybe I can solve it
December 22, 2013 09:14PM
hi gomez
thanks for the reply,,, the arm looks like this :
and the working diagram is like this :
i would be very grateful if you could provide me with a solution.. I am not a expert at this things...
thanks again
[imgur.com]
[imgur.com]
Edited 1 time(s). Last edit at 12/22/2013 09:15PM by ekaggrat.
December 22, 2013 11:51PM
ekaggrat
hi gomez
thanks again
[imgur.com]
[imgur.com]
We have x,y and we need two angles: one represents the height and the other the angle
first we need distance from x,y to axis :h= sqrt(x^2+y^2)
now angle between arms with law of cosines: angA= (L1^2+L2^2-h^2)/(2*L1*L2)
the angles of the parallelogram always add up to 360: angB=180-angA
calculate real height of arm: hA=sen(angB )*L2
height of arm's joint: hB=y-hA
ang2=asen(hB/L1)
ang1=angB+ang2
so to finish you have to do the next:
1°- angB=180-(L1^2+L2^2-x^2-y^2)/(2*L1*L2)
2°-ang2=asen(y-(sen(angB )*L2)/L1)
3°-ang1=angB+ang2
remember to copy the link finished at .jpg/.png/.* for the images
I like the arm design I'm going to use it at my printer
Edited 2 time(s). Last edit at 12/23/2013 02:36AM by Gomez.Marcos.
December 23, 2013 01:46AM
hi gomez..
thanks for the great solution ... I just couldn't understand what ang cool smiley is? is it ang B ?
assuming it is ang B i plugged the formulas into a excel and it doesn't seem to give a solution ... I think something is wrong....
Edited 1 time(s). Last edit at 12/23/2013 02:17AM by ekaggrat.
open | download - scara test.xls (17 KB)
December 23, 2013 02:17AM
yes, it is B
EDIT:
its true it have 2 errors one was of writing and the other is bigger lol
I used angB like ang1
give a me a minute
Edited 1 time(s). Last edit at 12/23/2013 02:36AM by Gomez.Marcos.
December 23, 2013 02:20AM
it gives a error when put into a excel...
December 23, 2013 03:46AM
the formulas should be as follows :
1°- angB=180-Acos((L1^2+L2^2-sqrt(x^2+y^2))/(2*L1*L2))
2°-ang2=Asin(y-(sin(angB*L2)/L1)
3°-ang1=angB+ang2
but even with this the solution fails when angB > 90 degrees ..
so i think this approach might not work
December 23, 2013 03:49AM
now works fine test it
reduced:
angB=180-ACOS((L1^2+L2^2-x^2-y^2)/(2*L1*L2))
ang2=90-(ACOS((L1^2-L2^2+x^2+y^2)/(2*L1*RAIZ(x^2+y^2)))+(ATAN(x/y))
ang1=ang2+angB
Edited 1 time(s). Last edit at 12/23/2013 03:57AM by Gomez.Marcos.
open | download - scara test.xls (24 KB)
December 23, 2013 04:28AM
works like a charm
thanks a ton..........
time to build it
Edited 2 time(s). Last edit at 12/23/2013 11:13AM by ekaggrat.
open | download - Frame_00000.gif (64 KB)
October 07, 2015 05:18AM
Finally done
hackaday
March 11, 2016 04:44AM
ekaggrat
Finally done
hackaday
This is so cool ekaggrat, I love the doodle clock.
If I had that on my desk I'd watch it for hours lol. Are the plans to build it anywhere?
March 12, 2016 01:33AM
@tomso
thanks
most of the stuff is here
hackaday project
the hardest part is winding the coils so it is not a easy build..
Ambidextrous SCARA IK
September 05, 2016 12:27AM
Here's an OpenSCAD animatable demo of SCARA kinematics showing how an arm can change orientation in some situations.
[gist.github.com]
| A major contributor to the Marlin Firmware project
| Help support my work at Patreon and GoFundMe
