SCARyllA: Dual (parallel) arm SCARA laser engraver build March 29, 2015 03:03PM |
Re: SCARyllA: Dual (parallel) arm SCARA laser engraver build March 29, 2015 03:17PM |
Re: SCARyllA: Dual (parallel) arm SCARA laser engraver build March 29, 2015 03:29PM |
Re: SCARyllA: Dual (parallel) arm SCARA laser engraver build March 29, 2015 04:40PM |
Re: SCARyllA: Dual (parallel) arm SCARA laser engraver build March 29, 2015 11:50PM |
Re: SCARyllA: Dual (parallel) arm SCARA laser engraver build March 30, 2015 01:10PM |
Re: SCARyllA: Dual (parallel) arm SCARA laser engraver build April 02, 2015 03:03PM |
Re: SCARyllA: Dual (parallel) arm SCARA laser engraver build April 02, 2015 03:39PM |
Re: SCARyllA: Dual (parallel) arm SCARA laser engraver build April 02, 2015 03:52PM |
Re: SCARyllA: Dual (parallel) arm SCARA laser engraver build April 04, 2015 06:37PM |
Re: SCARyllA: Dual (parallel) arm SCARA laser engraver build April 05, 2015 05:49AM |
Re: SCARyllA: Dual (parallel) arm SCARA laser engraver build April 29, 2015 04:05PM |
Re: SCARyllA: Dual (parallel) arm SCARA laser engraver build May 16, 2015 06:53AM |
Re: SCARyllA: Dual (parallel) arm SCARA laser engraver build May 16, 2015 04:36PM |
Re: SCARyllA: Dual (parallel) arm SCARA laser engraver build May 16, 2015 05:13PM |
Traumflug
Looking at the code changes so far it much looks like the other three types aren't too complicated. I'm a bit (positively) surprised how simple this apparently is. Just implement um_to_steps() and steps_to_um() for your mechanics and you're ready to go
Readme.scara
dda_maths contains modified conversions (new: scara_um_to_steps) from µm to
steps for scara-type printers.
dda.c uses the new method instead of the cartesian versions (um_to_steps_x/y).
Re: SCARyllA: Dual (parallel) arm SCARA laser engraver build May 16, 2015 07:04PM |
Re: SCARyllA: Dual (parallel) arm SCARA laser engraver build May 17, 2015 09:54PM |
Re: SCARyllA: Dual (parallel) arm SCARA laser engraver build May 18, 2015 04:25AM |
Re: SCARyllA: Dual (parallel) arm SCARA laser engraver build May 21, 2015 11:56AM |
Wally's problem was that is had a fixed stepper actuating a moving pully, which caused exact positioning of the arms to be a literally moving target.Quote
cozmicray
So how does this design overcome the problems surfaced in WALLY design?
Re: SCARyllA: Dual (parallel) arm SCARA laser engraver build May 24, 2015 12:03PM |
Re: SCARyllA: Dual (parallel) arm SCARA laser engraver build May 24, 2015 03:49PM |
Re: SCARyllA: Dual (parallel) arm SCARA laser engraver build May 25, 2015 02:45PM |
Re: SCARyllA: Dual (parallel) arm SCARA laser engraver build June 14, 2015 01:41PM |
Re: SCARyllA: Dual (parallel) arm SCARA laser engraver build July 02, 2015 02:31AM |
Re: SCARyllA: Dual (parallel) arm SCARA laser engraver build July 02, 2015 05:11AM |
lyscanthrope
The best bet with teacup would be to reuse the new framework made by traumflug.
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: SCARyllA: Dual (parallel) arm SCARA laser engraver build July 02, 2015 05:35AM |
Re: SCARyllA: Dual (parallel) arm SCARA laser engraver build July 02, 2015 07:41AM |
Re: SCARyllA: Dual (parallel) arm SCARA laser engraver build July 02, 2015 11:44AM |
Re: SCARyllA: Dual (parallel) arm SCARA laser engraver build July 02, 2015 01:57PM |
Re: SCARyllA: Dual (parallel) arm SCARA laser engraver build July 06, 2015 01:46PM |
