SCARyllA: Dual (parallel) arm SCARA laser engraver build
Posted by theothermike
Re: SCARyllA: Dual (parallel) arm SCARA laser engraver build
July 07, 2015 02:40AM
Just regarding our discussion on the kinematics : in this document you will find both the forward and the inverse
[www.ohio.edu]
Could be helpfull to check smiling smiley
July 07, 2015 06:32AM
Thanks for the link....while reading through it I remember that I already found it some months ago, but set it aside because it needs several steps of simplification into a more compact mathematical form.
But, indeed, it´s at least one calculation I can still compare ! :-)
July 30, 2015 03:44PM
Very slow progress...
Magnet holder and HES-box installed:
Distance between Clamp and HES-box surface is 0.5mm:
Best of all: Endstop switches are working ! :-)) x-motor port of Ramps-shield is right shoulder joint, y-motor port is left shoulder joint. Switches are connected to x-max pins.
Proof is here:
[youtu.be]
And that´s the arm position after homing:
Roughly measured, the real angles after homing are:
Theta (beta within my drawing): 113°
Psi (alpha within my drawing): 192°
which roughly corresponds to following coordinates:
x: -105 mm
y: +105 mm
OK, so far, I tried to modify the FW...unfortunately with no success.
I refer to this one: Marlin-armlevel
Within "Marlin_main.cpp" I switched Quentin Harleys with my inverse kinematics:
//++++++++++++++++++++Inverse Theothermike Begin +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
  SCARA_C2 = (pow(SCARA_pos[X_AXIS],2)+pow(SCARA_pos[Y_AXIS],2)-pow(Linkage_2/1000,2)+pow(Linkage_1/1000,2)) / (2 * pow(Linkage_1/1000,2)*sqrt(pow(SCARA_pos[X_AXIS],2)+pow(SCARA_pos[Y_AXIS],2)));
//checked
  SCARA_S2 =  pow(85.0-SCARA_pos[X_AXIS],2)+pow(SCARA_pos[Y_AXIS],2);     // pow(85.0-SCARA_pos[X_AXIS],2)+pow(SCARA_pos[Y_AXIS],2);
  SCARA_K1 = Linkage_1/1000-Linkage_2/1000;
  SCARA_K2 = 2*Linkage_2/1000*sqrt(pow(SCARA_pos[X_AXIS],2)+pow(SCARA_pos[Y_AXIS],2));
  SCARA_K3 = (SCARA_S2+SCARA_K1)/(SCARA_K2); // (SCARA_S2+SCARA_K1)/(SCARA_K2);
  SCARA_theta =(atan2(85.0 - SCARA_pos[X_AXIS],SCARA_pos[Y_AXIS])+3.1415927/2.0-(SCARA_K3)-pow(SCARA_K3,3)/6.0-3.0/40.0*pow(SCARA_K3,5)-5.0/112.0*pow(SCARA_K3,7)-35.0/1152.0*pow(SCARA_K3,9)-63.0/2816.0*pow(SCARA_K3,11)-231.0/13312.0*pow(SCARA_K3,13)-143.0/10240.0*pow(SCARA_K3,15)-6435.0/557056.0*pow(SCARA_K3,17)); //atan2(85.0 - SCARA_pos[X_AXIS],SCARA_pos[Y_AXIS])+acos((SCARA_S2+SCARA_K1)/(SCARA_K2));  //(atan2(85.0 - SCARA_pos[X_AXIS],SCARA_pos[Y_AXIS]) + acos((SCARA_S2+SCARA_K1)/(SCARA_K2)));
  SCARA_psi = atan2(SCARA_pos[X_AXIS],SCARA_pos[Y_AXIS])+3.1415927/2.0-(SCARA_C2)-pow(SCARA_C2,3)/6.0-3.0/40.0*pow(SCARA_C2,5)-5.0/112.0*pow(SCARA_C2,7)-35.0/1152.0*pow(SCARA_C2,9)-63.0/2816.0*pow(SCARA_C2,11)-231.0/13312.0*pow(SCARA_C2,13)-143.0/10240.0*pow(SCARA_C2,15)-6435.0/557056.0*pow(SCARA_C2,17);  //acos(SCARA_C2)+atan2(SCARA_pos[X_AXIS],SCARA_pos[Y_AXIS]);
  delta[X_AXIS] = 180 - SCARA_theta * SCARA_RAD2DEG;  // Multiply by 180/Pi  -  theta is support arm angle
  delta[Y_AXIS] = SCARA_psi * SCARA_RAD2DEG;  //       -  equal to sub arm angle (inverted motor)
//++++++++++++++++++++Inverse Theothermike End +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
Somehow, the FW has problems to calculate the inverse cosine function acos(). I spent hours and suddenly it was clear...therefore I approximated the acos() using its Taylor expansion at x=0.
At least it somehow calculates some values and jogging is possible.
Afterwards, the forward calculation was added in "Marlin_main.cpp":
 //################## Theothermikes Calculation for SCARyllA Begin.#################################################################################################
  // Perform forward kinematics, and place results in delta[0]
  float y1, y2, x1, x2, df0, df1, df2, df3;
  y1 = sin(f_delta[Y_AXIS]/SCARA_RAD2DEG) * Linkage_1 / 1000;
  y2 = sin(f_delta[X_AXIS]/SCARA_RAD2DEG) * Linkage_1 / 1000;
  x1 = cos(f_delta[Y_AXIS]/SCARA_RAD2DEG) * Linkage_1 / 1000;
  x2 = 85.0 + cos(f_delta[X_AXIS]/SCARA_RAD2DEG) * Linkage_1 / 1000;
  df0 = (sqrt(pow(df1,2) + pow(df2,2)))/(2 * Linkage_2/1000);
  df1 = (x2 - x1);
  df2 = (y2 - y1);
  df3 = atan2(df2 , df1) + 3.1415927/2.0-(df0)-pow(df0,3)/6.0-3.0/40.0*pow(df0,5)-5.0/112.0*pow(df0,7)-35.0/1152.0*pow(df0,9)-63.0/2816.0*pow(df0,11)-231.0/13312.0*pow(df0,13)-143.0/10240.0*pow(df0,15)-6435.0/557056.0*pow(df0,17);
  delta[X_AXIS] = x1 + Linkage_2/1000 * cos(df3) + SCARA_offset_x;
  delta[Y_AXIS] = y1 + Linkage_2/1000 * sin(df3) + SCARA_offset_y;
 //################## Theothermikes Calculation for SCARyllA END.#################################################################################################
Again, acos() was not working --> Same Taylor expansion.
Within "Configuration.h" settings using the measured coordinates after homing are:
// Manual homing switch locations:
// For deltabots this means top and center of the cartesian print volume.
// Scara: x centered, y 0
#define MANUAL_X_HOME_POS -105.0
#define MANUAL_Y_HOME_POS 105.0
#define MANUAL_Z_HOME_POS 210  // Distance between nozzle and print surface after homing.
Offsets equal zero, so that the "real" coordinates and angles should be given:
// SCARA tower offset (position of Tower relative to bed zero position)
// This needs to be reasonably accurate as it defines the printbed position in the SCARA space.
#define SCARA_offset_x 0.0 //mm
#define SCARA_offset_y 0.0 //mm
Steps per rev. settings are:
// default settings
#define DEFAULT_AXIS_STEPS_PER_UNIT   {711, 711, 100, 450}
#define DEFAULT_MAX_FEEDRATE          {300, 300, 300, 45}  // (mm/sec)
#define DEFAULT_MAX_ACCELERATION      {400, 400, 400, 8000}    // X, Y, Z, E maximum start speed for accelerated moves.
Currently the gear ratio is 1:80, motors exhibit 200 steps/rev and driver is set to 16x microstepping, yielding in a total of 256000 steps/rev = 711.111 steps/deg.
So far, so good. I think mechanical and electrical system is running as it should, but FW is still faulty.
I still do not understand how homing is working.
After homing, by submitting M114 to the device, the x,y-coordinates do not equal the setted home position and the angles are completely wrong.
After endswitch triggering, does the FW take the setted home coordinates and calculates the corresponding angles?
Perhaps I still have an error within the calculations or something during code execution goes wrong?
Do I need to swap motors?
In Quentin Harleys version, he multiplies Theta inside the IK by (-1). Why that? Have I missed some inverted motor direction?
However, when using the unmodified FW, it somehow correspond correct ( jogging +x --> movement -x, angles and home coordinates not too far away,..)
I will check calculation using an excel script or so...Really weird the Marlin-armlevel-FW....
July 31, 2015 08:06AM
Yeahh ! One error found !! It really helps posting here so one is forced to think deeper... :-)
Made an Excel Skript and *BAM* ........should have done that much earlier.
With this I can calculate the arm coordinates to be approx. x=-73 and y=105.4
I have to correct the inverse calculation. When calculating Epsilon, it must be divided by e, not c....
Photo will be posted asap.
Edited 1 time(s). Last edit at 07/31/2015 08:07AM by theothermike.
July 31, 2015 08:11AM
At least here´s the Excel script.
open | download - SCARyllA_IK_DK.xlsx (360.8 KB)
July 31, 2015 01:37PM
Here´s the corrected calculation:
On the right side, the argument in the epsilon term must be divided by "e".
August 01, 2015 07:19AM
Success !!! :-)))))) SCARyllA´s alive !
Of course, there were some more issues in my forward calculation program routine. But I was able to debug them using a different procedure.
I defined much more variables than initially needed, calculated each small term and printed them out using the serial-out.
Then I compared the values with the excel sheet and was able to correct each term separately.
But now homing works, software endstops work, jogging is fine, gcode acceptance at least seems to be fine.
This brings me to the next level and to do´s :
- Manufacture last aluminum parts.
- Fabricate Laser driver & holder.
- Clean up my firmware modification.
- House and mount the Arduino+Ramps.
- Readjust y-motors magnet holder (endstop position still lies in xy-workspace which is not good when hitting "homing" again).
- Write simple Arduino adjustment program & fabricate corresponding positioning device. I want to make a spacer which defines exact parallel arm positions. From there, jogging and counting steps until endstop triggers. Using the excel calculation the precise angles can then be defined.
With this it´s only a matter of time to enforce & unleash SCARyllAs indisputable power ;-))
August 01, 2015 01:01PM
Thats great news! Does the arm not have the weird bug that causes it to swing over at startup then?
[scara3dprinter.wordpress.com]
August 01, 2015 02:34PM
No strange swing.
Just the end stop switch homing routine, as it can be seen here:
[www.youtube.com]
The rest depends on where you set your bed zero coordinates, but they are reached in a linear, understandable manner.
Nevertheless, firmware still lacks g2/g3 codes ! :-((
I tested un-uncommenting the g2/g3 routines, but that gives movements out of bound.......
So, if anybody has an idea how to implement g2-movements, please let me know ! :-)
August 03, 2015 04:11PM
Hi.
This is working firmware for your mechanics.
Proof
Just modify values as you want
#define Linkage_1 70
#define Linkage_2 80
#define FiveBarAxesDist 0 // the distance beetween axes.
Plus extra math for mount bar controlled by:
#define EndPointMountOffset 18
#define EndPointMountAngle 50
Visualizer
August 04, 2015 01:18PM
right now testing Pavlo´s new Firmware.
Installation´s fine, yet the endstops are wrong....needing xy_max instead of xy_min, z_max is jumpered.
Edited 1 time(s). Last edit at 08/04/2015 01:21PM by theothermike.
August 04, 2015 01:45PM
Just tweak as your need values bellow (im my bot - steppers shaft looking down)
#define INVERT_X_DIR false    // for Mendel set to false, for Orca set to true
#define INVERT_Y_DIR false    // for Mendel set to true, for Orca set to false
and
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
Added:
Also you may change (i've updated git hub firmware - now it is in configuration.h)
 #define FBSIGN -1 // for 5 bar only
Edited 1 time(s). Last edit at 08/04/2015 01:59PM by PavloG.
August 04, 2015 02:20PM
What does "FBSIGN" do?
Edit: OK, I see in Marlin_main the parity is changed with it...
I setted:
and
But now the xy_max endstops are not effective any more..!
Using "M119" they definitely get triggered, but machine moves on!
Edited 1 time(s). Last edit at 08/04/2015 02:32PM by theothermike.
August 04, 2015 02:47PM
FBSIGN is a direction of rotation (in my setup it working right only with -1)
comment line with - #define DISABLE_XYMAX_ENDSTOPS to enable xy max
Again in my setup i used min endstoppers for homing.
August 04, 2015 02:49PM
OK, works !!!
It´s quite logical !! I had to mechanically change from x_max, y_max, z_max to the corresponding min pins.
Great stuff !
One further thing regarding the calculation of the offsets:
The mathematical base zero coordinates (x=0, y=0) without offset sits in between the two shoulder joints ?
August 04, 2015 03:11PM
Tried several combinations now....think there´s an error concerning the reversed motor direction and xy_max endstops. Nevertheless, it works using the xy_min pins.
This is my working configuration.h:
Configuration.h
Edited 1 time(s). Last edit at 08/04/2015 03:54PM by theothermike.
August 05, 2015 03:37AM
theothermike
Yes.
August 06, 2015 10:53AM
SCARyllA runs quite well using Marlin-5bar Firmware by Pavlo Gryb.
He made it accept g2/g3 commands, so path trajectories exported from inkscape, CAMBAM, etc. should work now!!
g2-movements can be seen here:
[www.youtube.com]
August 06, 2015 10:18PM
That is great to hear! Looks like I need to dust off my printer and update the firmware.
September 18, 2015 11:13PM
i'm very interesting and will make one,thank you for all.
Edited 1 time(s). Last edit at 09/18/2015 11:17PM by kinghonwill.
October 09, 2015 01:57PM
Hi Mike
Really nice work and thanks for sharing.
And thanks Pavlo Gryb for the Marlin-5bar Firmware.
I have had a parallel scara design on the table for a while, but as usual not much play time. But this thread has got me back to the urge of protoyping and making.
Going to try and keep everything in one chunk of metal for the arm drives and also the Z-Axis by trying to add rotating ballscrew nut configuration and holding the ballscrew thread solid in place. This will save a bit of space not having the usual stepper motor and coupler configuration and also no moving bed.
The chunk will contain 2 motors with harmonic drives for the arms and 1 motor to turn the ballscrew nut.
Will start a new thread showing the build as do not want to hijack this one but great stuff and a big help.
Cheers
Sean.
[www.cncdudez.co.uk]
October 09, 2015 03:01PM
Hi Sean,
thank you! Documentation here in the forum is also a giant help for myself.
Pavlo has really done great work, I already thought about asking him about ABL and multiple extruders but I´m not ready yet and do not want to be a stressor... ;-)
Unfortunately I currently have not so much time for it...but it will be better in some time.
Still I have to think about the laser mount. I would like to implement at least a small manual height adaption...
It will come and I will post it here.
Would be very interesting to see more about your design, especially the rotating ballscrew nut. So feel free to share your thread link ! ;-)
I already saw your scaras MK1-3 some months ago, which were also quite inspirating.
Where do you source your harmonic drives?
I also already searched for a more compact, integrated stepper-harmonic drive combination. The coupler arrangement here is one thing I also don´t like so much.
Ideally a HD with an integrated flat stepper would be ideal....but never found and "smart" stepper-gear combinations are a little bit too costly...
Kind regards,
Mike
October 09, 2015 04:48PM
Hi Mike
I need to post an update on the single arm Scara when I get time. Not had a lot of time to play with it as much as I would of liked, as it has been a busy year work wise.
That is the problem when you turn your hobby into a business, you end up with less play time trying to keep up with the demand of production products and less on the fun parts.
But it is great going to work and doing what you love each day, instead of working for The Man as such.
With the Scara MK3, I could not find any open source code that was suitable and good enough, so ended up designing our own controller and writing dedicated firmware/software.
The problem with that though is de-bugging and getting it to the stage where you are happy to release it. We made up a few units that are out in the hands of developers and being tested, so more on that design later on down the line.
We looked around for European supplies of the strain wave gearboxes and as usual Harmonic drives seem to be leading the way, but very expensive. We had the UK rep pop in and see us the other day at the workshop, with his case of samples and some really impressive products, but the price is crazy.
We sourced a company outside the UK and even though a long makeup time they produced a gearbox to our spec and it works really well ( I have attached a picture, these are 100:1 and fit nice onto a Nema17 motor). But just ordering in a few for doing prototypes is expensive, with them coming out at $1000 for a pair, but still cheaper than any European supplier.
But if we order in quantity the price does drop a lot and is actually viable to getting a model in production and keeping the price down. This is the way we would like to go in the future so we can produce cost effective machines, but also be able to offer a low cost, yet accurate gearbox to the hobby users for their own designs. I seriously cannot believe someone has not done this so far with the pace that Mechatronics has evolved over the last few years.
The design of the rotating ballnut is looking pretty good this end and a simple case of fixing the ballscrew either end to base plate and top mount so it is static and then setting up a bearing to house the ballnut, combined with a pulley connected to the ballnut and another Nema 17 motor that is mounted in main block. I have sourced suitable, off the shelf bearings and waiting from out supplier to see if they can make the custom ballnuts to suit.
I have allowed 100mm spacing between each arm link to the motors and the block ends up being about 170mm wide and 110mm high with all motors and gearboxes contained within. So now you just need to add the static ballscrew/Thread and a couple of linear rails. This makes life easy to extend the height to suit your needs. Just swap out the ballthread and longer rails.
So all good fun as usual
Cheers
Sean
open | download - CNCDesignHarmonic.jpg (80.1 KB)
dk
April 12, 2018 12:49PM
Hi everyone
I need to build a laser engraving machine with a field of 1200x1200mm. For a number of reasons for this project suited only SCARA arm. Single or parallel Scara.
I am inspired by your work and wanted to ask if you could help me with.
Theothermike - can you please share foto of printed parts? How precise and how fast SCARyllA can print?
Evil Monkey - how your printer work with this firmware?
Pavlo - can your firmware work on Smoothie board or Duet2 or any other 32 bit boards?
April 12, 2018 04:42PM
RepRapFirmware on Duet supports serial arm SCARA but not yet parallel arm SCARA.
April 16, 2018 11:41AM
1200x1200mm is a rather massive thing to want, you probably want to go with a single arm SCARA or double your costs with four long segments rather than two, then you can just use Duet
April 16, 2018 11:42AM
Also, hi David Crocker! Love your ir sensor!
