started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z May 25, 2015 07:51AM |
1) rep-rap to the bones: the current design has only bearings and bolts/washers as metal components, about everything else is plastc (and the fishing line, which is a vitamin but is plastic again)
2) no specialized or hard to find parts (linear rails, linear bearings, aluminum extrusions, etc)
3) low vitamin count, preferably more of the same kind than different ones (for emergency replacements/etc)
4) no timing belts, until we can print them, fishing line or other type of strong thread will be used instead
5) large printing area
6) multiple configurations and enhanced mobility: on the wall, on the floor, folded for transportation
7) as little metal as possible because of its energy intensive extraction and processing
8) precision over speed (complicated printed parts are allowed if achievable as they can be easily produced initially on another printer of similar precision)
9) can print larger versions of itself (should be easily scaled up by modifying a small number of components)
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z May 25, 2015 03:02PM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z May 25, 2015 08:25PM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z May 25, 2015 09:22PM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z May 26, 2015 04:01AM |
. This is a good suggestion, I was vaguely thinking of something completely off the bot which is not serving my goals
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z May 26, 2015 08:42AM |
theothermike
Second question: Already tried to run the Morgan-software as-is and move some motors with it? I had no success up to now.
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z May 26, 2015 09:04AM |
Z-axis wire tensioner (idea) May 26, 2015 09:18AM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z May 26, 2015 03:11PM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z May 26, 2015 04:28PM |
cozmicray
You sure like to write
and in 5 or 6 different forums?
Perhaps a Rube Goldberg forum also --- but you may need way more complicated steps/mechanisms
and this suggestion may not be complicated enough for your system
... and providing your wise friendly answers
... to all of those.
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z May 26, 2015 11:54PM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z May 27, 2015 05:19AM |
Evil Monkey
Are you going to limit the arms movement to avoid hitting singularities?
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z May 28, 2015 05:37AM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z May 28, 2015 07:49AM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z May 28, 2015 10:05PM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z May 28, 2015 10:18PM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z May 29, 2015 03:42AM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z June 02, 2015 11:02AM |
? Unfeasible
? Not worth it
? Awesome?
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z June 02, 2015 08:39PM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z June 03, 2015 03:07AM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z June 03, 2015 08:15AM |
theothermike
Interesting idea....but, well, I doubt that it will be efficient in this way.
You should think about maximizing the channels cross section (enhance Diameter/length ratio).
Less channels with larger cross section is much better because flow resistance goes up with pow(radius,4) and those small fans don´t have a high pressure difference!
Hollow square arm with four triangular flow channels ("x in a square") and some crossports might be beneficial for giving low flow resistance and rigid structure.
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z June 03, 2015 08:58AM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z June 03, 2015 09:30AM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z June 03, 2015 09:15PM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z June 04, 2015 05:09AM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z June 04, 2015 08:03AM |
and need to be cared for like babies.|
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z June 04, 2015 01:05PM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z June 04, 2015 02:33PM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z June 04, 2015 02:50PM |
... no cooling needed
and will need a hotend mount anyway. ...I will get back to the winch eventually, there's no pressure to finish the design. I will do incremental improvements as I get some answers from the true engineers out there... if
. I also bet my hopes on Nic helping with the winch as he expressed his interesting in testing it, because that needs quite a lot of thinking, CAD skills and engineering experience.|
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z June 04, 2015 09:19PM |
