Does anybody have experiments with Scara config setup? I'm trying to use the Morgan Scara (Smoothieware) set up and I'm not quite sure about the offset and scaling parameters.
morgan_offset_x 0 In the case of a morgan arm solution, X offset
morgan_offset_y 0 In the case of a morgan arm solution, Y offset
axis_scaling_x 0.8 In the case of a morgan arm solution, scaling in the X axis
axis_scaling_y 0.8 In the case of a morgan arm solution, scaling in the Y axisj
