Homemade Scara printer need help
Posted by papo
May 06, 2018 03:35PM
Re: Homemade Scara printer need help
May 17, 2018 12:00PM
honestly can't hear what you're saying in your video but hey, what do you need help with? Looks like you've got everything you need and are making good progress!
May 29, 2018 06:46AM
need a board that can run scara any suggestions
May 31, 2018 03:12AM
any ramps board can run a scara printer . just dont go crazy with highly segmented models.. most firmwares now support a scara printer. the easiest firmware to modify for scara is smoothie
June 01, 2018 01:09PM
papo
RepRapFirmware on Duet supports serial SCARA in the standard distribution binary. Most other firmwares these days support SCARA if you recompile them with SCARA support enabled.
8-bit processors struggle to run SCARA printers unless the print speed is set very low. Whether that is a problem for you will depend on whether your SCARA mechanics are capable of higher speeds.
