... sourcing parts for a parallel SCARA
Posted by VDX
VDX
December 05, 2019 03:15PM
Hi all,
... got some interesting parts from a friend, perfectly suited for building a parallel SCARA cool smiley
This are Z+A axes from industrial dispensers, so two of them with synchronized moving in Z and rotating the "arm-shoulders" are the "core" of the parallel SCARA:
The steppers are Vexta 5-phase types, so will replace them wit 2-pase-steppers, for lack of 5-ph-drivers ...
Viktor
Re: ... sourcing parts for a parallel SCARA
December 19, 2019 07:22AM
you'll be balancing pens in no time [www.youtube.com]
VDX
December 19, 2019 04:47PM
... not my intention - but will allow a 4DOF parallel SCARA, if allowed for "skewing" the working plane between the two "shoulders" smoking smiley
Viktor
December 21, 2019 04:54AM
Skewing is a nice idea to support milling cutters in CNC eg. If you build one and use Duet RRF version 3, I can help with software (I mean the necessary RRF3 firmware).
Edited 1 time(s). Last edit at 12/21/2019 04:58AM by JoergS5.
VDX
December 21, 2019 03:31PM
... hmmm ... could be a variant too -- have a Duet2 Ethernet lying around ... have to swap all 5-phase steppers for bipolar ones then ...
Viktor
December 21, 2019 04:09PM
RRF 3 is possible for Duet 2 Ethernet. I have created a RRF 2 version already for parallel Scara which is tested by user bondus, but without your idea of screwing.
Please tell me when you are sure whether want to implement it. I don't want to waste time if you don't use it. But I will implement it if you want to use it.
The current documentation is in [duet3d.dozuki.com]
and the current RRF 2 firmware is in [github.com]
VDX
December 21, 2019 05:29PM
... actually simple plain movement would be OK - the "skewing" is only a theoretical option ... should be much easier with a separate tilt+pan unit on the table ...
Viktor
December 21, 2019 05:49PM
Then you can use the RRF2 version and in January I'll migrate to RRF3 and make a push to the official RRF. I have a Duet 2 and 3 and will test with both.
The skewing has the disadvantate that it tilts only into specific directions. I am not sure whether it's worth using or better implement separate axes at the hotend/tool point. The skewing angle changes with position, which makes kinematic more complex. But I already thought about two Z axis actuators to support calibration in respect to the print bed.
