Cura - problems printing
Posted by plennon
December 17, 2012 03:50PM
Hello Romscraj,
Thanks for the quick delivery - I got the portabee, assembled it and i'm now trying to print.
I've got a problem with printing with Cura. I load an image into Cura and select Prepare Print. Once the image is ready i click print. It connects to the printer and i can move the on all axis using the jog feature. I then select print and wait. I can see the temperature increasing to the required settings. The progress bar does not move unless i click pause/resume but nothing happens.
I have even changed the scale of the print model to 0.1 so that it is only trying to print a very small object.(236 lines in total), but it does not start to print.
Any ideas why it doesn't start printing.
Re: Cura - problems printing
February 18, 2013 12:58AM
Hi Plennon,
it sounds like you are having problems connecting to your reprap.
Under preferences choose the com port and the baudrate for your reprap.
For your portabee i think the baud rate is 250000.
try it again if not use print run it is easier to connect and control your prints with it.
p.s
i do not work for romscraj.
Regards
