Tapered barrel screw extruder help January 17, 2011 07:53PM |
Re: Tapered barrel screw extruder help January 18, 2011 03:24AM |
Admin Registered: 18 years ago Posts: 14,170 |
Re: Tapered barrel screw extruder help January 18, 2011 10:54AM |
)----by tapering,I don't mean to an extent where screw tip would be too small, so that shouldn't be a problem....The screw root i presume would be less than 12mm in diameter, thats where I need help because I can't figure out exactly how much. Also, I can't figure out what taper angle (mostly it should be some angle between 0 to 2 degree) suits best... Any idea? |
Re: Tapered barrel screw extruder help January 18, 2011 02:49PM |
Re: Tapered barrel screw extruder help January 20, 2011 09:46AM |
Re: Tapered barrel screw extruder help January 24, 2011 04:47AM |
Re: Tapered barrel screw extruder help January 24, 2011 10:07AM |
Re: Tapered barrel screw extruder help January 24, 2011 05:50PM |
Re: Tapered barrel screw extruder help January 25, 2011 02:15PM |
Re: Tapered barrel screw extruder help April 05, 2014 08:24PM |
