Developing Solenoid-Valve extruder for biomaterials, but signal and voltage are tricky to incorporate
Posted by JoshuahMG
Hi there,
I have been designing a 3D printer that's on the same infrastructure as Prusa i3 for bioprinting. However, I am not sure how to use my new extruder, which is a pressure-based solenoid valve.
Essentially, the valve is powered by a Spike and Hold, not a PID like Prusa i3 is. This spike and hold requires 24 V in the first millisecond and then 5 V for the hold voltage. As you already know, Arduino cannot exceed 24 V or else it will burn out the circuit. In addition, the Marlin software that powers this model is for PID.
My question is this: how can I redesign the printer for the solenoid signal without damaging the Arduino?
I've only just read your message, so I guess you have solved it already. If not, it's easy to do with a few electronic components.
Delta printer calibration calculator, mini IR Z probe, and colour touch screen control panel: [escher3d.com]
Large delta printer, and other 3D printer blog postings: [miscsolutions.wordpress.com]
Disclosure: I have a financial interest in sales of the Panel Due, Mini IR height sensor, and Duet WiFi/Duet Ethernet.
Just sent you a PM. I can show you what I've diagramed here if necessary.
