How do we both encourage RepRap mutations and stay focussed? March 26, 2008 05:25PM |
Admin Registered: 17 years ago Posts: 177 |
Re: How do we both encourage RepRap mutations and stay focussed? March 26, 2008 06:08PM |
Admin Registered: 17 years ago Posts: 1,915 |
Re: How do we both encourage RepRap mutations and stay focussed? March 27, 2008 05:06AM |
Admin Registered: 17 years ago Posts: 179 |
Re: How do we both encourage RepRap mutations and stay focussed? December 17, 2010 01:13AM |
Re: How do we both encourage RepRap mutations and stay focussed? March 03, 2011 10:54PM |
Re: How do we both encourage RepRap mutations and stay focussed? March 04, 2011 05:38AM |
Admin Registered: 17 years ago Posts: 7,879 |
None of these are a language where you can throw a switch from "METRIC" to "SAE" or vice versa and have related measurements for dimensions, holes and threads take on different values according to macros that access that value to decide whether they use, for example, M8 bolts or 5/16 inch bolts.
Re: How do we both encourage RepRap mutations and stay focussed? March 04, 2011 02:15PM |
Re: How do we both encourage RepRap mutations and stay focussed? March 04, 2011 02:41PM |
Admin Registered: 15 years ago Posts: 1,470 |
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing. Anyone can edit the wiki! |
Re: How do we both encourage RepRap mutations and stay focussed? March 04, 2011 02:58PM |
Re: How do we both encourage RepRap mutations and stay focussed? March 06, 2011 10:26AM |
Re: How do we both encourage RepRap mutations and stay focussed? March 09, 2011 04:43PM |
Re: How do we both encourage RepRap mutations and stay focussed? March 09, 2011 04:52PM |
Re: How do we both encourage RepRap mutations and stay focussed? March 10, 2011 04:45AM |
Admin Registered: 16 years ago Posts: 13,888 |
Re: How do we both encourage RepRap mutations and stay focussed? March 10, 2011 06:46PM |
Re: How do we both encourage RepRap mutations and stay focussed? March 11, 2011 04:54AM |
Re: How do we both encourage RepRap mutations and stay focussed? March 11, 2011 05:06AM |
Constructive solid geometry From Wikipedia, the free encyclopedia
One of the advantages of CSG is that it can easily assure that objects are "solid" or water-tight if all of the primitive shapes are water-tight. This can be important for some manufacturing or engineering computation applications. By comparison, when creating geometry based upon boundary representations, additional topological data is required, or consistency checks must be performed to assure that the given boundary description specifies a valid solid object.
A convenient property of CSG shapes is that it is easy to classify arbitrary points as being either inside or outside the shape created by CSG. The point is simply classified against all the underlying primitives and the resulting boolean expression is evaluated. This is a desirable quality for some applications such as collision detection.
Boundary representation From Wikipedia, the free encyclopedia
Compared to the constructive solid geometry (CSG) representation, which uses only primitive objects and Boolean operations to combine them, boundary representation is more flexible and has a much richer operation set. This makes boundary representation a more appropriate choice for CAD systems. CSG was used initially by several commercial systems because it was easier to implement. The advent of reliable commercial B-rep kernel systems like Parasolid and ACIS, mentioned above, has led to widespread adoption of B-rep for CAD. As well as the Boolean operations, B-rep has extrusion (or sweeping), chamfer, blending, drafting, shelling, tweaking and other operations which make use of these.
Re: How do we both encourage RepRap mutations and stay focussed? March 11, 2011 05:40AM |
Re: How do we both encourage RepRap mutations and stay focussed? March 11, 2011 06:27AM |
Re: How do we both encourage RepRap mutations and stay focussed? March 11, 2011 06:28AM |
Re: How do we both encourage RepRap mutations and stay focussed? March 11, 2011 06:32AM |
nophead
It is disappointing to find that OpenScad has similar issues to AOI with coincident faces, etc.
Re: How do we both encourage RepRap mutations and stay focussed? March 11, 2011 07:21AM |
2.4 Objects
Objects are the building blocks of your scene. There are a lot of different types of objects supported by POV-Ray. In the sections which follows, we describe "Finite Solid Primitives", "Finite Patch Primitives", "Infinite Solid Primitives", "Isosurface Object", "Parametric Object", and "Light Sources". These primitive shapes may be combined into complex shapes using "Constructive Solid Geometry" (also known as CSG).
The basic syntax of an object is a keyword describing its type, some floats, vectors or other parameters which further define its location and/or shape and some optional object modifiers such as texture, interior_texture, pigment, normal, finish, interior, bounding, clipping or transformations. Specifically the syntax is:
Re: How do we both encourage RepRap mutations and stay focussed? March 11, 2011 07:44AM |
Re: How do we both encourage RepRap mutations and stay focussed? March 11, 2011 08:25AM |
Re: How do we both encourage RepRap mutations and stay focussed? March 11, 2011 08:48AM |
Re: How do we both encourage RepRap mutations and stay focussed? March 11, 2011 08:55AM |
Re: How do we both encourage RepRap mutations and stay focussed? March 11, 2011 09:09AM |
Re: How do we both encourage RepRap mutations and stay focussed? March 11, 2011 06:31PM |
Re: How do we both encourage RepRap mutations and stay focussed? April 17, 2011 10:05AM |
Re: How do we both encourage RepRap mutations and stay focussed? April 17, 2011 10:18AM |
Re: How do we both encourage RepRap mutations and stay focussed? April 17, 2011 10:33AM |
