Cast aluminum parts huh? Sounds pretty cool. I always thought that aluminum was pretty expensive. What are the materials costs if you don't mind my asking?
Also considering this will be working in metal you could cut some of the overall cost by tapping the parts and eliminate a lot of the nuts. (of course then you get back into SAE vs Imperial supply chain issues.) Is that possible with your process?
Are the parts going to be LM8UU compatible?
PS. You'll get better reaction on these forums if you post only to the relevant category rather than spamming every list you can find.
Edited 1 time(s). Last edit at 02/02/2012 04:16PM by bryanandaimee.
