I'm not aware of one, that also depends on the type of electronics you have. Usually, it's pretty obvious: four wires to each motor, two to the heater, two to the thermistor as well as power supply and USB connection. Make sure electronics and power supply share a common ground, i.e. connect the PSU's housing to the electronics' GND. Gen3 has extra requirements.
