circuit
Posted by guzzi
circuit
April 20, 2011 02:25AM
Is there a circuit diagram that shows the final completed product with all the connections.
Re: circuit
April 20, 2011 05:54AM
I'm not aware of one, that also depends on the type of electronics you have. Usually, it's pretty obvious: four wires to each motor, two to the heater, two to the thermistor as well as power supply and USB connection. Make sure electronics and power supply share a common ground, i.e. connect the PSU's housing to the electronics' GND. Gen3 has extra requirements.
Re: circuit
April 20, 2011 06:08AM
guzzi
There is a G3 wiring diagram.
For the rest, as Traumaflag says- it depends on your electronics you are using.
