Fuction of GCodes in RepRap host software April 30, 2012 01:56PM |
Re: Fuction of GCodes in RepRap host software May 01, 2012 04:13PM |
Re: Fuction of GCodes in RepRap host software May 02, 2012 05:46AM |
E codes are usually in mm of filament input into the extruder.
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Fuction of GCodes in RepRap host software May 02, 2012 11:57AM |
This looks like what i was looking for.Quote
I generally use this as my reference: [reprap.org]
Are you sure? In the following is a part of a test object. You can see E values like G1 E1250.0 without any move in the XY axes. I think that is too much for mm.Quote
I was thinking about to use the official gcode generator. But i will investigate the Slic3 option.Quote
However, Slic3r [slic3r.org] can slice objects and output code for Mach3/EMC. Why not use that?
My plan is to use as litle firmware as posible. The extruder motor will be controlled by EMC so i need to know what the E values represent to calibrate the fourth axle of EMC. This is one of the reasons that i prefer to use just one gcode generator.Quote
True for some slicers, others measure the output. So a G-code interpreter has to support both, usually by supporting variable STEPS_PER_MM_E.
Re: Fuction of GCodes in RepRap host software May 02, 2012 12:56PM |
| FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
| Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Fuction of GCodes in RepRap host software May 02, 2012 04:15PM |
Re: Fuction of GCodes in RepRap host software May 03, 2012 12:53PM |
