Vertical X-axis PCB Mill carriage September 14, 2011 07:17AM |
Re: Vertical X-axis PCB Mill carriage September 14, 2011 10:05AM |
Re: Vertical X-axis PCB Mill carriage September 14, 2011 11:11AM |
Re: Vertical X-axis PCB Mill carriage September 14, 2011 02:12PM |
Re: Vertical X-axis PCB Mill carriage September 14, 2011 04:35PM |
Re: Vertical X-axis PCB Mill carriage September 15, 2011 03:01AM |
Re: Vertical X-axis PCB Mill carriage September 15, 2011 04:43AM |
Re: Vertical X-axis PCB Mill carriage September 15, 2011 05:40AM |
evidence from CNC machines shows that MDF and other wood-based machines expand and contract to a measurable degree depending on humidity.
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Vertical X-axis PCB Mill carriage September 15, 2011 08:11AM |
Admin Registered: 17 years ago Posts: 7,879 |
A Mendel with only printed and wooden parts, anyone?
Re: Vertical X-axis PCB Mill carriage September 15, 2011 09:43AM |
nophead
Yes that is what I am working on ATM, see [forums.reprap.org]. All the studding frame is replaced by a few sheets of 12mm MDF, much stiffer in the directions it needs to be. I doubt it would be much good for milling due to the use of belts, but it would be a lot better than a normal Mendel.
Re: Vertical X-axis PCB Mill carriage September 15, 2011 12:35PM |
Re: Vertical X-axis PCB Mill carriage September 15, 2011 01:26PM |
Re: Vertical X-axis PCB Mill carriage September 15, 2011 07:59PM |
Re: Vertical X-axis PCB Mill carriage September 16, 2011 07:26AM |
Re: Vertical X-axis PCB Mill carriage September 16, 2011 10:08AM |
