Pronterface problem
Posted by berdejayant
Pronterface problem
October 23, 2012 01:36AM
Im having a problem with pronterface. When I turned off any switch(not the 1 to which printer is connected), printer goes offline. Plz help me out
Re: Pronterface problem
October 23, 2012 01:42AM
And USB port is also not working. What should I do to fix this problem?
VDX
October 24, 2012 04:47PM
... mains problems?
Viktor
October 27, 2012 01:42AM
I had a similar problem when I added an 18 inch USB extension cable. Keep your USB cables short, or, if you need to exceed about 2 meters, add a powered USB hub in the middle.
October 31, 2012 03:00PM
Low quality USB cables will mess you up equally bad
