New Printer
Posted by sbloom67
New Printer
March 31, 2014 06:07PM
So I would like to build a new printer. But I would like to use 4 z-axis motors. Do any of the 3d printer boards handle 4 z axis, 2 y axis and 1 x axis along with somewhere between 2 - 4 print heads. Also does merlin firmware even handle it ???
Thanks
Re: New Printer
April 01, 2014 08:46AM
You could bodge something up connecting the enable, step and dir pins for the z motor(s) from RAMPS for example to either 2or4 stepper drivers on some prototyping board. You don't need firmware support because they would all step at the same time. I say 2 or 4 because you could drive 2 motors from a single driver either in parallel or in series as is done by many printers now (mainly prusas and derivatives).
Re: New Printer
April 02, 2014 12:20AM
Greg Frost
DRV8825 drivers are great for this: 2.2A with proper cooling. You could probably run 3 steppers off of one driver, if you do things right. Four off two would be a piece of cake.
