Hello,
I have questions above welcome menu for LCD 16x2. I want to change firmware. I use Marlin V1 firmware.
When it is printing from SD card,I want to see how much percent is done.
In
configuration.h I have
#define REPRAP_DISCOUNT_SMART_CONTROLLER
#define ULTIPANEL
#define NEWPANEL
I thing it will be change
ultralcd_implementation_hitachi_HD44780.h
I try it, but I was not successfull. Can you help me?
#if LCD_WIDTH < 20
lcd.setCursor(0, 0);
lcd.print(itostr3(tHotend));
lcd.print('/');
lcd.print(itostr3left(tTarget));
# if EXTRUDERS > 1 || TEMP_SENSOR_BED != 0
//If we have an 2nd extruder or heated bed, show that in the top right corner
lcd.setCursor(8, 0);
# if EXTRUDERS > 1
tHotend = int(degHotend(1) + 0.5);
tTarget = int(degTargetHotend(1) + 0.5);
lcd.print(LCD_STR_THERMOMETER[0]);
# else//Heated bed
tHotend=int(degBed() + 0.5);
tTarget=int(degTargetBed() + 0.5);
lcd.print(LCD_STR_BEDTEMP[0]);
# endif
lcd.print('/');
# endif//EXTRUDERS > 1 || TEMP_SENSOR_BED != 0
#else//LCD_WIDTH > 19
lcd.print('/');
lcd_printPGM(PSTR(LCD_STR_DEGREE " "));
if (tTarget < 10)
lcd.print(' ');
lcd.setCursor(10, 0);
# if EXTRUDERS > 1
# else//Heated bed
# endif
lcd.print('/');
if (tTarget < 10)
lcd.print(' ');
#endif//LCD_WIDTH > 19
#if LCD_HEIGHT > 2
//Lines 2 for 4 line LCD
# if LCD_WIDTH < 20
# ifdef SDSUPPORT
lcd.setCursor(0, 2);
lcd_printPGM(PSTR("SD"));
if (IS_SD_PRINTING)
lcd.print(itostr3(card.percentDone()));
else
lcd_printPGM(PSTR("---"));
lcd.print('%');
# endif//SDSUPPORT
# else//LCD_WIDTH > 19
# if EXTRUDERS > 1 && TEMP_SENSOR_BED != 0
//If we both have a 2nd extruder and a heated bed, show the heated bed temp on the 2nd line on the left, as the first line is filled with extruder temps
lcd.setCursor(0, 1);
lcd.print('/');
if (tTarget < 10)
lcd.print(' ');
# else
lcd.setCursor(0,1);
lcd.print('X');
lcd.print(ftostr3(current_position[X_AXIS]));
lcd_printPGM(PSTR(" Y"));
lcd.print(ftostr3(current_position[Y_AXIS]));
# endif//LCD_WIDTH > 19
lcd.setCursor(LCD_WIDTH - 8, 1);
lcd.print('Z');
lcd.print(ftostr32(current_position[Z_AXIS]));
#endif//LCD_HEIGHT > 2
