The Least Unique Part Count Machine July 07, 2016 04:09PM |
Re: The Least Unique Part Count Machine July 07, 2016 07:17PM |
Re: The Least Unique Part Count Machine July 07, 2016 07:25PM |
Admin Registered: 13 years ago Posts: 7,001 |
Re: The Least Unique Part Count Machine July 08, 2016 11:53AM |
Re: The Least Unique Part Count Machine July 08, 2016 12:03PM |
Re: The Least Unique Part Count Machine July 08, 2016 01:11PM |
Re: The Least Unique Part Count Machine July 08, 2016 01:31PM |
Re: The Least Unique Part Count Machine July 08, 2016 03:30PM |
I get that, but the stated point of the thread is to build a bot with a low unique part count. I'd challenge you to create a Cartesian bot with a lower unique part count than a Delta. You have identical "tower" assemblies and identical arms. Top and bottom plates could be the same too.Quote
MechaBits
I mean for Cartesian bot, like mine or the ormerod or similar 3 axis layout.
Re: The Least Unique Part Count Machine July 08, 2016 04:17PM |
Re: The Least Unique Part Count Machine July 08, 2016 06:42PM |
I have a count for "my" delta, but it was designed with my tooling capabilities in mind which are quite extensive. I also used linear guides, which increase the screw count, but I suppose not the unique part count by much. You could lower my parts count greatly by making compromises in adjustability and or precision (using a different guide system) I can tell you that as part of my design process that a significant factor was specifically number of unique parts to make, and a good percentage of the reason I chose a delta design. You want me to count everything? Include motors etc? Are you using a heated bed? Just to compare apples to apples.Quote
marcin_ose
Ok, decent point, but now let's get more rigorous. Count the unique parts for the delta, down to individual nuts etc - and compare to the cartesian. We'll do our count as soon as we finalize the design. Do you have a count for the Delta as a benchmark?
Re: The Least Unique Part Count Machine July 08, 2016 11:23PM |
Re: The Least Unique Part Count Machine July 19, 2016 03:42PM |
Re: The Least Unique Part Count Machine July 19, 2016 07:16PM |
I have 48 unique parts not Mechabits. There are tons of designs for deltas posted online including a nice BOM. I don't typically post pictures of my designs sorry.Quote
marcin_ose
MechaBits - this is good, thank you. Would you mind showing a picture of your machine, including label 1-48 for the parts? That sounds like a really good count.
Please see our update on the design - [youtu.be]
Thanks,
Marcin and Michel
Re: The Least Unique Part Count Machine July 20, 2016 08:36AM |
