C#: Appending the data received from a Serial Port to a list of string? October 15, 2012 11:59AM |
//Fields List myReceivedLines = new List(); SerialPort port; //subscriber method for the port.DataReceived Event private void DataReceivedHandler(object sender, System.IO.Ports.SerialDataReceivedEventArgs e) { SerialPort sp = (SerialPort)sender; while (sp.BytesToRead > 0) { try { myReceivedLines.Add(sp.ReadLine()); } catch (TimeoutException) { break; } } } protected override void SolveInstance(IGH_DataAccess DA) { //Opening the port if (port == null) { string selectedportname = default(string); DA.GetData(1, ref selectedportname); int selectedbaudrate = default(int); DA.GetData(2, ref selectedbaudrate); //Assigning an object to the field within the SolveInstance method() port = new SerialPort(selectedportname, selectedbaudrate, Parity.None, 8, StopBits.One); //Enables the data terminal ready (dtr) signal during serial communication (handshaking) port.DtrEnable = true; port.WriteTimeout = 500; port.ReadTimeout = 500; } //Event Handling Method bool connecttodevice = default(bool); DA.GetData(3, ref connecttodevice); if (connecttodevice == true) { if (!port.IsOpen) { port.DataReceived += new SerialDataReceivedEventHandler(DataReceivedHandler); DA.SetDataList(0, myReceivedLines); port.Open(); } } else if (port.IsOpen) { port.DataReceived -= new SerialDataReceivedEventHandler(DataReceivedHandler); port.Close(); } if (port.IsOpen) { DA.SetData(1, "Port Open"); } //If the port is open do all the rest if (port.IsOpen) { bool homeall = default(bool); DA.GetData(5, ref homeall); //What happens when input is set if (homeall == true) { port.Write("G28" + "\n"); } } else { DA.SetData(1, "Port Closed"); } }
Re: C#: Appending the data received from a Serial Port to a list of string? October 15, 2012 12:09PM |
Re: C#: Appending the data received from a Serial Port to a list of string? October 15, 2012 12:16PM |
