Pronterface
October 23, 2012 06:09AM
Why Im getting message that "Cant write to printer(?disconnected)" midway 3D printing? Plz help
Re: Pronterface
October 23, 2012 06:42AM
I get that as well - it seems that the USB connection is sensitive to electrical noise.
Can you download onto an SD card and print from that?
Anyone know of a proper fix?
Re: Pronterface
October 23, 2012 06:50AM
I am using SD card slot only
Edited 1 time(s). Last edit at 10/23/2012 06:59AM by berdejayant.
Re: Pronterface
October 23, 2012 08:51AM
Another problem Im having is when I turned off any electrical device in the room(say fan), Printer gets stop. Why this happening. Is there any interference between connections? Plz help me out
Re: Pronterface
October 23, 2012 11:42AM
It might be worth asking again with a different subject - this isn't pronterface's problem
Re: Pronterface
October 23, 2012 02:42PM
Try putting the printer on an Uninterruptible Power Supply.
Andy
Re: Pronterface
October 24, 2012 10:03AM
Is this problem Im getting because of Pronterface software or due to the electric connections in the room?
Re: Pronterface
October 24, 2012 10:08AM
Mark: Im using pronterface. Thats why i post this message under pronterface subject.
Re: Pronterface
October 25, 2012 12:55AM
Andy: putting printer on an Uninterruptible Power Supply means exactly what to do? See, Im new to this and dont understand these electrical terms
Re: Pronterface
October 25, 2012 02:20AM
Can there be a programming problem?
Re: Pronterface
October 25, 2012 08:47AM
Andy: Now I get what u trying to say. Ur solution sounds good. I will try this and get back to u. Probably with positive results
Re: Pronterface
January 05, 2013 05:26PM
This is a bit old and in the wrong section however:
This problem can be caused by a loose connection in the power connector to the main board.
I recommend unscrewing the connector from the cable, tin the ends with solder, then firmly re attach the connector.
Halitus
Re: Pronterface
January 14, 2013 01:48AM
I have this problem constantly.
Interestingly, moving the Fan to a further away circuit reduced the chance of a failure 95% but not entirely.
I suspect the problem is that ATX power supply is a crappy source that can't handle surges.
You heard it here first.
Re: Pronterface
January 14, 2013 06:41AM
You could try to filter your power supply with a phat capacitor. Large electrolytics are pretty cheap. Solder a large resistor across the legs so it self discharges.
Edited 1 time(s). Last edit at 01/14/2013 06:43AM by konwiddak.
Re: Pronterface
January 14, 2013 02:31PM
If your fan is consistently giving you trouble...[www.beam-wiki.org]
- akhlut
Just remember - Iterate, Iterate, Iterate!
[myhomelessmind.blogspot.com]
Re: Pronterface
January 14, 2013 11:26PM
> that?
Yes it is in fact. Any "noisy" motor or electrical surge on the same circuit as my reprap, will kill my Ramp's connection to Pronterface.
Re: Pronterface
August 21, 2013 03:30AM
user a much shorter Quality usb cable, you can insulate it from electrical noise if you must, just using a shorter hq cable should resolve this issue
I had this issue having my 3d printer plugged into the same power socket as my hi power battery chargers, putting out like 3kw.
had some kind of inductive effects
Re: Pronterface
August 22, 2013 03:32AM
there is no solution to electical noise... one way or the other it will interrupt the print... best way is to print from a sd card... believe me i have had this problem and came to the sd card after changing almost 10 usb cbles , ferrite cores ... two power supplys .... etc etc etc....dont waste your time just get a sd card.....
Re: Pronterface
August 28, 2013 04:35PM
I had one arduino that was particularly susceptible to this. Swapping it out basically solved the problem. I realise that isn't a great help, but it is a data point.
Re: Pronterface
October 26, 2013 11:12PM
Has anyone checked the ground between controller and power supply?
