Re: Full Color 3d Printer Project May 22, 2014 12:46PM |
ekaggrat
@gyrobot
any chance of sharing the script. the aprinter frimware supports gcode for two extruders in the following format : " g1 x100 y100 e10 u 20 " if you could share your script i could change it to that format and then use it on my dual color mixing extruder...
thanks
Re: Full Color 3d Printer Project August 21, 2014 05:03PM |
Re: Full Color 3d Printer Project August 21, 2014 07:00PM |
Re: Full Color 3d Printer Project August 31, 2014 02:10PM |
Re: Full Color 3d Printer Project September 10, 2014 08:58AM |
Re: Full Color 3d Printer Project September 10, 2014 06:54PM |
Miertam
Has anyone tried mixing laser toner into natural filament? it should become bonded at around 200C.
Thanks Mike
Re: Full Color 3d Printer Project September 10, 2014 08:41PM |
Re: Full Color 3d Printer Project September 11, 2014 05:38AM |
Alayax
Just had a look at the Duet page that dc42 mentionend (http://reprap.org/wiki/Duet ) and that looks perfect for the job.
Alayax
Right now my experimental machines's steppers won't step smoothly, so I have to solve that first before I can test any of that. No matter where I set the trim pot, they just won't turn smoothly. It is a Techzone Huxley, and I can not find the exact step motor specs to adjust the current to. If anyone knows, or knows where to find the specs, please let me know.
Alayax
Has anybody thought of designing a board that has "real time electronic control" over the current? Would be handy if it needs more holding torque for a few seconds (like light CNC machining, or wiping the nozzle clean). I am better at mechanical, and not so much at electronics and code, so please feel free to tell me to stick to stuff I know about if it is not possible or practical.
Re: Full Color 3d Printer Project October 15, 2014 03:24AM |
Re: Full Color 3d Printer Project October 15, 2014 12:53PM |
Re: Full Color 3d Printer Project October 15, 2014 02:00PM |
Re: Full Color 3d Printer Project October 15, 2014 05:01PM |
Re: Full Color 3d Printer Project October 15, 2014 06:01PM |
Re: Full Color 3d Printer Project October 16, 2014 03:06AM |
Re: Full Color 3d Printer Project October 23, 2014 03:24AM |
Re: Full Color 3d Printer Project November 03, 2014 07:27PM |
Re: Full Color 3d Printer Project November 03, 2014 10:46PM |
Re: Full Color 3d Printer Project November 03, 2014 11:14PM |
Re: Full Color 3d Printer Project January 14, 2015 02:25PM |
Re: Full Color 3d Printer Project January 15, 2015 04:34AM |
Re: Full Color 3d Printer Project January 15, 2015 12:09PM |
Re: Full Color 3d Printer Project January 20, 2015 11:20AM |
Re: Full Color 3d Printer Project January 27, 2015 04:34PM |
Leak-free mixing is really the hardest part. I suspect a direct mechanical linkage to the stirrer will be required which would require a dynamic seal that does not leak at high temperatures and pressures. Alternatively we could emulate existing processes and use a long screw whose geometry forces the plastic forward. This would essentially be identical to a pellet extruder and provide reliable mixing at the cost of long switches.Quote
haskinsl
I have a very crude concept for an active mixing extruder...
Re: Full Color 3d Printer Project January 27, 2015 05:00PM |
Re: Full Color 3d Printer Project January 29, 2015 05:20PM |
Re: Full Color 3d Printer Project January 31, 2015 06:00PM |
Re: Full Color 3d Printer Project February 01, 2015 01:43PM |
Re: Full Color 3d Printer Project February 01, 2015 05:45PM |
Re: Full Color 3d Printer Project February 02, 2015 09:48AM |
Re: Full Color 3d Printer Project February 03, 2015 09:14PM |
i work with a group of 4 people caled &makers and i'm starting a bussiness with, if someone read italian here an article that talk about us and what we are going to do:&makers, we have build the hotend with 7 treaded M5 holes with the right angle, here the image, of course will need help to control 6 color mixing, i'm pretty sure to finish the hardware and test in this month, anyone is active in this project?
